Go to Post When it comes to FIRST (you've all heard the cliche) -- we're all winners. When it comes to the competition: to the engineering design challenge, we're NOT all winners -- some solutions are better than others. - JVN [more]
Unread 24-12-2014, 16:47
ThunderPorpoise's Avatar
ThunderPorpoise ThunderPorpoise is offline
AKA: Benjamin Hollinger
FRC #4373 (RooBotics)
ThunderPorpoise is an unknown quantity at this point
What kind of cylinders does your team stock?
I'm looking into purchasing some pneumatic cylinders for my team and I'm a bit swamped by how many options there are. What do your teams keep in stock for various tasks that you might need to accomplish? (In terms of Bore, Stroke, Double or Single Acting, etc.)
Unread 24-12-2014, 17:32
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: What kind of cylinders does your team stock?
We "stock" the leftovers from previous robots, and the ones we bought for previous robots that didn't work out quite right. We find we usually use 3/4" bore by 1, 2, 3, 4, 6, 8" stroke, and we have a pair of 1.5" bore x 8" stroke that have been used in a few different robots.
Unread 24-12-2014, 17:39
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
We keep an assortment of double acting cylinders from 1/2" to 3" bore and 1/2" to about 12" stroke. We like to have at least two of each in case we need one on each side of a system. 225 gave us some small single acting cylinders at Midknight Mayhem so maybe we'll get a chance to use them this year. One thing that we need to work on is keeping clevises for all cylinder sizes in stock.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 24-12-2014, 17:47
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
This is as close to exactly what I was going to say that I don't need to change anything.
Unread 24-12-2014, 19:27
Chris is me's Avatar
AKA: Pinecone
Cylinders are really the kind of thing you order once you know your design, or at least know what you're prototyping. McMaster sells them so we can get them in a day or two, and for everything else we use cylinders from old robots. Generally always double acting, front and rear pivot mounting.
Unread 24-12-2014, 21:22
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Curious here... It was my understanding that parts that are used on a bot cannot be reused on a later bot if it is modified. Technically speaking wouldn't putting fittings into an air cylinder make it no longer off the shelf?
The way it was explained to us lends itself to just that. Same holds true for transmissions and such ( hence why we haven't gone with two speed trans yet)
Unread 24-12-2014, 21:30
Technically... Yes. But the cylinder can be restored to COTS by removing those fittings. Takes 5 minutes or less. (OK, maybe plugging the output ports too.) And then you put the fittings back in.
You could also reference R16 from the 2014 rules, covering an edge case.
To answer the original question... 1197 has a couple of 2" bore, 24"+ throw cylinders laying around the shop (one in original packaging!), in addition to the usual 3/4" and 1.5" bores in various lengths. The big cylinders are primarily useful for "Hey, who wants a strong, slow, and heavy air-hogging mechanism?"
Unread 24-12-2014, 21:41
dradel's Avatar
So by your reasoning a team could reuse cylinders, transmissions, compressor, swerve drive and so on if they disassemble then reassemble ?
Unread 24-12-2014, 21:47
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
We won't know the 2015 rules for another week-ish, but under 2014 and prior rules anything restored to identical COTS condition is legal for reuse.
Art Dutra IV
世上无难事,只怕有心人.
Unread 24-12-2014, 22:04
AKA: Pinecone
...And then when you take them back off, it returns to being a COTS item.
If they are off the shelf items, with no modifications whatsoever, yes absolutely. Hundreds of teams reuse compressors every year.
If the swerve drive happens to be a bought product, and again if the parts are unmodified, it needs to be restored to an off-the-shelf state and then it can be reused.
Any custom made parts, any COTS parts modified by machining, anything you actually "made" cannot be reused. So this is why teams design and build new drive bases every year. But if both drive bases use Toughboxes, and they didn't add any mounting holes or otherwise change them, reusing is functionally identical to buying another. So to save teams money it's permitted to take those COTS Toughboxes and put them on a NEW custom drive base, for example.
Again, *any* modification (that isn't / can't be reversed) changes the part from COTS to a custom part and it cannot be reused.
All of this post assumes the 2015 rules are similar to the rules in 2014 and before.
Unread 24-12-2014, 22:07
dradel's Avatar
Thanks for the explanation !! Changes things dramatically for our team!!
Unread 25-12-2014, 00:12
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Personally I can't see FIRST changing the rules regarding reusing COTS items, it would just place an unnecessary expense on teams. Especially this season with the fact that new motor controllers were introduced/approved so late and the potential for there being shortages of them.
Unread 25-12-2014, 00:59
AdamHeard's Avatar
Lead Mentor
Agreed. We let mcmaster (and Automation direct) stock them for us!
Unread 26-12-2014, 14:15
Dave Campbell's Avatar
Dave Campbell Dave Campbell is offline
Miami Valley Planning Committee
FRC #0144 (ROCK Robotics)
Dave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant future
Feeling a bit spoiled as our main team sponsor is Clippard Instruments.... we stock every COTS cylinders, fittings, valves and tubing in their catalog. In addition, they hire students from my program and our team members to work for the company, custom making many parts for our machine....check them out here: Clippard
Yes, they are the same company that donate the Volume Storage Tanks to all FRC teams.
A true FIRST partnership in action!
"Great spirits have always encountered violent opposition from mediocre minds." - Albert Einstein
FRC Team #144 Advisor
Unread 26-12-2014, 15:30
Oblarg Oblarg is offline
AKA: Eli Barnett
This.
You get three bimba cylinders every year in the KOP, so it doesn't take all that long to build up a collection. Clevises and pivot brackets, on the other hand, are a perennial issue.
A tip: Use a vise to knock out the pin that comes in the rear-pivot assembly of the bimba cylinders, and use a bolt instead. It's far more convenient.
"The breakfast of champions!"
