Go to Post Baker, you're making my head hurt and it's only August!!!! - Rich Kressly [more]
Unread 25-12-2014, 22:49
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
2067 LabVIEW Code: Swerve, Auto Scripting, Gyro
Our LabVIEW code has been public on GitHub, but I thought I should share it here, in case any teams find some of the code to be useful.
Here is the 2014 Robot Code: https://github.com/applepi-2067/Robot-2014
Features:
Swerve Drive
4 wheel independent swerve.
After rewriting the swerve code a few times, I feel that this current version is fairly elegant and easy to understand. If any LabVIEW teams are interested in our code, it's all in the "Swerve Drive" folder. There's also a presentation describing how it works.
If you want to see what it looks like, here's an image of the main swerve block, and here's an image of Swerve Wheel.vi, which is used to control one wheel.
Autonomous Scripting
This was never actually used in competition; I wrote it during the summer. It's called AppleScript, and is designed to be easily updated on the fly in a competition. The autonomous script is stored on the driver station computer, and when you make changes to it, the code is immediately updated on the robot, without need for redeploying code. A one ball auto might look like this:
(I made some custom syntax highlighting on Notepad++). There's also a manual for this scripting language.
Since I wrote the code somewhat recently, it's not bug-free. A few weeks ago, I had trouble writing a two ball auto, as the command timer wasn't functioning correctly. I think I fixed it, but I haven't been able to test my changes. The code is under the "AppleScript" folder on the GitHub repo.
Custom Gyro Code
During the season, our main problem with swerve was dealing with gyro drift and whatnot. In the offseason, I rewrote the gyro library, which alleviated most of the problems. The code is based off Chris Hibner's great advice here. Basically, the gyro is continuously calibrated (bias is calculated) up until the start of the match. Our code actually has support for up to two gyros, one mounted upside down, one facing up. We tested this setup to see if it would help the gyros behave better, but the results for that were rather inconclusive. This code is under the "Gyro" folder on the GitHub repo.
Head Programmer / Driver
Unread 26-12-2014, 01:48
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Re: 2067 LabVIEW Code: Swerve, Auto Scripting, Gyro
Note: might want to pick a better name for your auto scripting language... http:// https://developer.apple.com/...SLR_intro.html
Otherwise thanks for posting this
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 26-12-2014, 03:09
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Thanks for posting code! This will come in very handy for swerve teams.
Also, Applescript is neat.
Unread 26-12-2014, 11:26
cjl2625's Avatar
apel py
AKA: Cory Lynch
Yeah, I recently noticed this. I was too lazy to rename everything, though
Unread 26-12-2014, 12:28
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
If like to see the presentation but get an error when I click it. Can you check the link?
Unread 26-12-2014, 12:56
cjl2625's Avatar
apel py
AKA: Cory Lynch
See if this one works:
https://docs.google.com/presentation...p=docslist_api
Unread 26-12-2014, 13:41
FRC #6054 (Dukes)
Much better. Thanks for sharing.
Unread 27-12-2014, 09:50
pimathbrainiac's Avatar
pimathbrainiac pimathbrainiac is offline
Today, Regionals. Tomorrow, Worlds.
AKA: Philip N
FRC #1127 (Lotus Robotics)
pimathbrainiac can only hope to improve
dude this is awesome. Is the scripting LabView-only?
Unread 27-12-2014, 11:28
cjl2625's Avatar
apel py
AKA: Cory Lynch
The script interpreter is written in LabVIEW, so that probably means yes.
