Go to Post Yeah those design flaws kill you in the end. You especially hate finding out about them in competition. - Koko Ed [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 27-12-2014, 15:05
Bonzabonz Bonzabonz is offline
FRC #5052 (RoboLobos)
Bonzabonz is an unknown quantity at this point
Good Material For Bottom of Chassis
What is a good covering for the bottom of the robot chassis to mount things like the control system, battery, compressor, pneumatic manifold, motor controllers, etc.? Last year was my team's rookie year and be used a piece of pegboard (something like this). Probably needless to say, it didn't really hold up too well under the weight of heavier items (mainly the battery) and started to fall apart from the stresses of competition. I was wondering what other teams liked to use and what their experiences with different materials were.
Unread 27-12-2014, 15:08
Re: Good Material For Bottom of Chassis
Baltic birch plywood, if you can find some, cuts well and looks nice--and it's an insulating material. It's also pretty light.
Unread 27-12-2014, 15:12
RandomStyuff RandomStyuff is offline
FRC #2212 (Spikes)
RandomStyuff is a jewel in the roughRandomStyuff is a jewel in the roughRandomStyuff is a jewel in the roughRandomStyuff is a jewel in the rough
I know many teams use some forms of plastic, mostly polycarbonate.
I've also seen teams use aluminium plate with nylon bolts for attaching parts.
Because using your robot's cannon to shoot at your nation's Minister of Education is worth all the 6 weeks of no sleep!
Unread 27-12-2014, 15:17
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
Plywood will work fine, as long as you make sure it is adequately supported around the battery area. We used 3/16" for the belly pan (as well as the rest of the chassis) and it holds up fine.
Unread 27-12-2014, 15:20
Mike Marandola Mike Marandola is online now
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
I have heard of teams using birch plywood, G-10 or garolite, and perforated polycarb. Just as a side note, we have used 1/16" perforated 3003 aluminum sheet for our bellypan and I would not recommend it. It sagged and bent around the edges like crazy. Maybe go thicker if you can find it, or 6061, but that is very expensive.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 27-12-2014, 15:25
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
1/4 to 1/2" plywood usually works ok, although you need to provide some extra bracing under the battery unless it's right at the edge of the robot. Pegboard is not very strong....plywood is stronger. If you want to get fancy, you can use plastic or metal, but you might find that plywood gives you more stiffness for the weight, and is easy to attach stuff to, and the insulating is a good thing as well. It's not quite as "high tech" looking as other materials, for whatever that is worth.
Unread 27-12-2014, 15:29
Ekcrbe's Avatar
Ekcrbe Ekcrbe is online now
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
You'd do best to avoid placing the battery directly on the bellypan/electrical board without other framework. The best thing to do would be to integrate some sort of specific case for the battery with the rest of the framework on the robot.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 27-12-2014, 15:49
theCADguy's Avatar
theCADguy theCADguy is offline
Design Team Student Leader
AKA: Sean Gibbons
FRC #0020 (The Rocketeers)
Team Role: CAD
theCADguy has a spectacular aura abouttheCADguy has a spectacular aura about
For the past 2 years at least, Team 20 has used Garolite for the past two years to cover the bottom of our chassis, as well as to mount the majority of our electronics. I cannot remember the thickness we used, probably 1/8". So far, it has worked well for us, since it's lightweight and relatively strong.
Unread 27-12-2014, 16:00
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
1/4" plywood is what I recommend. To stiffen it up a piece or two of 1x1 angle placed on the top works well to support the battery. If you space it just slightly larger than the battery so the edges of the battery rest on it then you've got the battery constrained in one axis. Use a small piece of the 1x1 angle to make a bracket to attach it to the frame on each end.
Unread 27-12-2014, 16:20
Michael Hill's Avatar
Can you machine on garolite easily? I've been thinking about using it, but hear bad things like delaminatione can happen.
Unread 27-12-2014, 16:43
theCADguy's Avatar
AKA: Sean Gibbons
Team Role: CAD
I'm not too sure about the machinability, but as far as I know, we haven't had any major issues as of yet.
Unread 27-12-2014, 17:08
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
We used 1/8" polycarbonate sheet last year and it worked great. More commonly available at Home Depot, Lowes, and Menards than birch plywood, which can be somewhat of a specialty item. Polycarbonate sourced there is cheaper than the sheets that AndyMark stocks.
I would avoid using construction grade SPF plywood in a 3/8" thickness, as its quality varies widely and won't hold up as well as birch, which has more glue in it.
You'll find that acrylic sheet is also available and cheaper, but you shouldn't use it. It breaks too easily, and the broken pieces are quite sharp.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 27-12-2014, 17:14
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
We're experimenting with a custom carbon fiber composite belly pan. We're taking a thick foam core and CNC'ing grooves for strength, for a battery holder, and for mounting electrical components. Then we layer this in sheets of glass fiber and carbon fiber, epoxy it, and vacuum out the excess air while it cures. This takes more time and more planning, but has given us a much better result than the 1/16th aluminum that we used last year.
Unread 27-12-2014, 17:43
BeardyMentor BeardyMentor is offline
Just the right amount of Crazy
AKA: Matt Hagan
FRC #1257 (Parallel Universe)
BeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud of
Plywood, polycarbonate, and sheet aluminum are all going to work well for this. Plywood and polycarbonate are a bit better than the aluminum in my opinion. The reason for this is it makes sure any electronics you mount to it are electrically isolated from the frame. Though, this is almost as easily done with double sided tape or Velcro. The take away from this is, use what ever material meets your budgetary and aesthetic needs.
One thing to note, If you want to use this as an element to stiffen up your chassis, use more screws than you would think. More smaller screws are better in this regard. One 10-24 screw every 4 inches or so around the perimeter works pretty well. Much better than just securing the corners.
Unread 27-12-2014, 17:48
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Originally Posted by BeardyMentor View Post
The reason for this is it makes sure any electronics you mount to it are electrically isolated from the frame..
The 2015- control system does not have any components with grounded cases that require isolated mountings.
