Go to Post We call ourselves community/family. We are. Our kitchen table where we gather is the size of Chief Delphi. - JaneYoung [more]
Unread 26-12-2014, 09:33
FantasticNinjas FantasticNinjas is offline
FRC #3205
FantasticNinjas is an unknown quantity at this point
Post FRC Computer Vision Code
For the past couple weeks I have been working on creating a system for recognizing FRC hot targets and determining distance to them. This is a work in progress, and any feedback / suggestions people have would be much appreciated.
GitHub Repository
Unread 28-12-2014, 03:56
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Re: FRC Computer Vision Code
Are you planning on using OpenCV? Right now it looks like you're writing everything from scratch and that's going to take a very long time to do.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 28-12-2014, 14:06
FRC #3205
I have already figured the whole thing out, I am just implementing what I already have planned on paper at this point. Also, I looked at the code for openCV, and while it is a very powerful framework, using it for this would be a performance nightmare. The first version of this actually used openCV. I spent over a week optimizing it, but it still ran slow. OpenCV is an truck; I need a sedan.
Unread 28-12-2014, 19:14
Djur's Avatar
WPILib
AKA: Sam Carlberg
Are you planning to run this code on the roboRIO or the driver station? I know OpenCV got built for the roboRIO but I'm not sure if it was ever benchmarked.
OpenCV should run fine on a decent driver station (so no classmate). I got it working last year at about 30 fps on a crappy three year old Alienware laptop.
Unread 28-12-2014, 22:39
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
OpenCV has been around since June of 2000 and was initially developed in Russia...
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 29-12-2014, 11:07
FRC #3205
We're planning on running it on the roboRIO. A major reason we are doing this in the first place is for the autonomous portion, during which communication with the driver station is prohibited.
Crappy Alienware laptop? My team's drive station is a 2009 white macbook with a core 2 duo processor and 2gb ram. Oh, and to control the robot it needs to be running windows in a VM . I would not be surprised if running the vision code on the roboRIO would be faster anyway (I'm only mostly joking).
Unread 29-12-2014, 12:03
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
This doesn't happen. The robot is always has communication with the driver station.
Unread 29-12-2014, 12:49
FRC #3205
You're right. This is my first year being part of FRC, so I only know what the rest of my team has told me. I could have been confused or they could have been confused, but either way, thanks for the information.
At this point I'm not entirely sure whether we will be doing the vision processing on the drive station or the roboRIO. The roboRIO has a slower processor, but sending an image from the camera to the roboRIO, then to the modem, and then to the drive station sounds like a lot of latency.
Unread 29-12-2014, 16:50
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
We tried this last year and with the right settings it worked OK, the problem is the FTA had to talk to us because we were exceeding our bandwidth limit since the image we were sending was too high resolutions.
The other problem we had was we didn't account for the diamond plating on the driver station so the reflection from the LED ring was tricking our vision tracking software into thinking it was a target.
Unread 29-12-2014, 19:11
Djur's Avatar
WPILib
AKA: Sam Carlberg
The OpenCV codebase was compiled to run on the roboRIO. I'm not saying that it was created for the roboRIO.
You don't have to run your vision stuff in the VM. OS X can still connect to the robot and you can run your java app there, although I still wouldn't expect it to process images at any more than 15 fps because of the Duo (for comparison, my laptop was running an i5-2537M). 15 fps should be fine if you don't try to use it to shoot or aim when the robot's going full speed.
If that happens, your code should ignore "targets" smaller than some threshold. Then you'd only be processing the real targets.
Unread 06-01-2015, 14:00
Cmxu Cmxu is offline
FRC #3205
Cmxu is an unknown quantity at this point
Sorry for taking up everyone's time, but the communication on this team has been rather poor coming into this season. First of all, we are running our vision code on the computer and I am not worried about processing power or speed. Second of all, we will be using openCV for our vision processing. After reading your code, I'm not sure it's right for the job. In the past, we have had bandwidth issues with our camera, and I think that somehow got miscommunicated to our newer members.
