Go to Post And when the President of the United States is playing with LEGOs and getting down on the floor to look inside of robots, then I would have to say "Mission Accomplished". - OZ_341 [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 28-12-2014, 21:27
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
Re: Good Material For Bottom of Chassis
we use aluminium road signs that were donated to us. we have been careful mounting our components and haven't had any issues. there are non conductive paints out there and we may try some this year to be safe.
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
  #32   Spotlight this post!
Unread 28-12-2014, 23:25
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
We use polycarb to mount the electronics (thicker stuff for cRio than for the motor controllers etc) except for the battery. Lately our sheet metal sponsor is making fancy battery trays for us but in years past we used aluminum angle to stick-build reliable battery trays.
Being flexible with the battery location is a plus. If you can move it around a little (as the last design step) you can get the robot's COG just right.
  #33   Spotlight this post!
Unread 29-12-2014, 00:39
philso philso is offline
FRC #2587
Originally Posted by Qbot2640 View Post
Be careful interchanging the terms "Birch" and "Baltic Birch". The former is just an appearance grade plywood with a birch veneer for cabinet making. What you really want for a strong bellypan is the latter - Baltic Birch. The core layers are solid birch as well as the outer veneer, and with no voids. This material is excellent for many robotics applications. It is light, strong, and holds screws extremely well. "Just plain birch" plywood is attractive, but the inner cores are made of a cheaper grade of wood and can contain voids and imperfections.
Also worth noting, American plywood is getting thinner - often you will see 23/32 rather than 3/4. The Baltic Birch is a European product, thus it is usually available in mm sizes...the 9mm is a great thickness for bellypan - a hair thicker than 3/8.
Probably the best way to purchase Baltic Birch is to find a specialty hardwood supplier where you live (Houston Hardwoods and Clarks Hardwoods in Houston, TX). Rockler sells 24" x 30" pieces as well as 12" x 30" pieces in 1/8", 1/4", 1/2" and 3/4" thicknesses. Lee Valley Tools also sells thick Finnish Birch Plywood in 3mm x 25" x 25". Lastly, you can try a local hobby shop that serves the model airplane builders but they are likely to be more expensive and they might only carry small pieces.
  #34   Spotlight this post!
Unread 29-12-2014, 02:37
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
This seems like a good thread to ask these questions:
For those of you who have used Garolite, I was thinking of purchasing 1/16th" Machineable grade Garolite from Mcmaster-carr to use as the bellypan of our chassis this upcoming season. I had some questions about machineability, mainly with drilling holes. I'd like to use a waterjet to cut the patterns I need out, but I'd imagine the impact of the water would be too much for the Garolite. Should i go about manually drilling out any holes, or look for CNC routing options?
Also, would 1/16" be enough to hold the battery and other various electrical components without sagging, or should I go for a thicker sheet?
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
  #35   Spotlight this post!
Unread 29-12-2014, 04:10
Mike Marandola Mike Marandola is online now
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Just to let you know, I only have firsthand experience with G-10. I am not sure about waterjetting Garolite, but 1/16" would be too thin even with supports, especially when you put holes in it. I would go up to 1/8" and have a battery carriage mounted to the frame to prevent sagging.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
  #36   Spotlight this post!
Unread 29-12-2014, 04:36
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
I would think that water jetting it would work fine. Water jetting is used for many delicate items because it doesn't damage them. It's all about the right settings for the material.
  #37   Spotlight this post!
Unread 29-12-2014, 07:39
Tom Line's Avatar
Tom Line Tom Line is online now
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We use expanded / foamed PVC. Isolated, easy to cut and drill, stiff and lightweight. It also comes in a number of colors. Your local plastic or sign shop will usually have it in 4x8 sheets.
  #38   Spotlight this post!
Unread 29-12-2014, 07:41
Gdeaver Gdeaver is online now
FRC #1640
Garolite comes in many classes. G-10 and G-11 are probably what you want. 1/16 is a little thin, 1/8 is probably a min. You could get the thinest g-10 and glue it to both sides of some structural foam. Could also do it with some honeycomb material. This would give a strong composite board with out the hassle and mess of laying up a composite board.
Woodcrafters carries Baltic Birch.
http://www.woodcraft.com/family/2004113/plywood.aspx
What ever board you use, Get some nylon hardware to mount stuff.
http://www.mcmaster.com/#machine-screws/=v8em46
  #39   Spotlight this post!
Unread 29-12-2014, 08:02
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
We use this stuff too, in a 6mm thickness.
  #40   Spotlight this post!
Unread 29-12-2014, 08:24
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
I have access to as much of this stuff as I want for free but I would be very hesitant to use it on a FIRST robot. It will crack easily under impact, especially when drilled trough.
I can see how it may be useful in this situation but I always hesitate to use something this fragile on a competition robot.
  #41   Spotlight this post!
Unread 29-12-2014, 08:40
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
In the past, my team has had the resources to do an aluminum diamond bellypan. But for those who don't, I highly, highly recommend this stuff. I use it for several applications in my high power rocketry endeavors (fins, mostly). A bit pricey, but it has very good strength, and much better stiffness than plastics of comparable thickness, all at almost unbelievably low weight. It consists of two pieces of very thin G10, with a honeycomb structure joining them.
  #42   Spotlight this post!
Unread 29-12-2014, 10:17
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
As usual, I'm baffled as to why so many teams go to so much effort to keep weight off the very bottom of the robot. The belly pan is the perfect place to let there be some heavy, stiff, strong material.
But this thread has shown us several neat lightweight materials that I'd be eager to use higher up on the robot.
  #43   Spotlight this post!
Unread 29-12-2014, 11:40
Michael Hill's Avatar
It allows us to allocate more weight to other parts of the drive if we want. For example, saving some weight in the bellypan lets us use steel axles and #35 chain or even allocate more weight to the gearbox.
  #44   Spotlight this post!
Unread 29-12-2014, 12:24
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Baltic Birch plywood is my recommendation. Easy to work with, not resource intensive (other than the cost), lightweight, adds a lot of rigidity, easy to add things later if your design changes... lots of advantages. We got two 5'x5' sheets for $43ea from a local hardware store.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
  #45   Spotlight this post!
Unread 29-12-2014, 16:16
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
In theory, weight and stiffness down low is very important.
In general, a few pounds is a few pounds and can be a whole new feature.
As an inspector, peg board tends to get fall apart around 4 or 5th match unless very well supported structurally (IE not a 4 zipties...). By the way, ziptieing your control board with pretty much any material seems to be a big likelihood of it falling apart. My biggest recommendation is use button head fasteners pointing up (so the round head faces the carpet) and fender washers to help support it in several locations.
Use some angle pices to support your battery and a good strap to hold it down. Hint, if your robot accidentally flips upside down, your battery should stay put.
