Go to Post If there are no top tier teams, then who do we look up to for inspiration? - artdutra04 [more]
Unread 29-12-2014, 09:26
BeardyMentor BeardyMentor is offline
Just the right amount of Crazy
AKA: Matt Hagan
FRC #1257 (Parallel Universe)
BeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud of
Re: Swerve Encoder and Wiring Questions
depending on what you need to do, there are some easier ways to hack together an encoder. I probably would not use these hacks on an FRC robot, but for a testing platform, they are fine.
If all you want to do is sense speed, acceptable results can be had with a reflective sensor like this http://www.robotmesh.com/line-tracki...ONYaAgcT8P8HAQ and using some white and black paint on the shaft of the wheel. If you want something with a bit more resolution you can use a pair of hall effect sensors and attach magnets to the rotating object.
Unread 29-12-2014, 09:58
Originally Posted by BeardyMentor View Post
If all you want to do is sense speed...
The present discussion is about measuring steering angle.
