Go to Post Getting that degree is the reason for going to college. Failing out of school because you mentored isn't really a good reason. - [more]
Unread 01-03-2003, 20:35
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
view obstruction
I was wondering - I've seen a couple teams that use large fabric sails to bush boxes around on the playing field. My question is (if these sheets are opaque) what will happen if a team using such sheets were to unfold them and position themselves directly in front of the oposing alliance's driver station, effectively destroying all visibility of the playing field? Would this be against the rules? (cause it would definitely make people not like you...)
I'm not pointing any fingers here - teams that have used sails most likely did not have this in mind when designing they're robots. I am only asking this question because i am concerned about a possible strategy that is (i think) currently allowed and would completely destroy the spirit of the competition.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 01-03-2003, 20:38
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Delibrately obstructing the drivers' view is againts the rules. If the robot is on the ramp, it should be no problem, but directly in front of the drivers would be a no-no.
Jeff Waegelin
Unread 01-03-2003, 20:39
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
If you still can't see, what's the difference?
--Madison--
...down at the Ozdust!
Unread 01-03-2003, 20:41
Solace's Avatar
AKA: Jake
the difference would be that a robot on the ramp would obstruct the views of both alliances equally.
...What is a man,
Jake
Team Paragon #571
Unread 01-03-2003, 20:42
Solace's Avatar
AKA: Jake
But Is that stated in the rules?
...What is a man,
Jake
Team Paragon #571
Unread 01-03-2003, 20:43
El Jefe de 148
What do you mean? When I said that, I meant that doing it on the ramp serves a purpose (blocking and/or knocking bins down). Putting a sail in front of the drivers station is solely for the purpose of blocking the opposing teams' vision.
Jeff Waegelin
Unread 01-03-2003, 21:19
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
Although not strictly speaking against the rules, FIRST has ruled every year that deliberately obstructing a team's vision would not be "graciously professional."
I think it would be really unfortunate if such a tactic were employed against us; however, visibility is going to be a major issue this year and planning a counter strategy would be wise.
Unread 01-03-2003, 21:21
Madison's Avatar
FRC #0488 (Xbot)
Well, if it is against the rules, specifically, to block an opposing alliance's view, where and how you do it ought not be irrelevant.
I don't know if it's actually in the rules, as such, though. It doesn't concern me enough to check.
If robots with sails use them to knock down bins, that's acceptable. If, however, they remain deployed and serve to block the view of the other alliance, I can't see how that is any different.
--Madison--
Unread 01-03-2003, 21:27
Jeff_Rice's Avatar
Jeff_Rice Jeff_Rice is offline
ElementisRegamusProelium
#1359
Jeff_Rice will become famous soon enoughJeff_Rice will become famous soon enough
Blocking the vision of the opposing team would be totally against the spirit of gracious professionalism, or, as I put it, common decency. This has been brought up before, though I cannot find where.
But on a lighter note, I'm sure everyone has talked about it, at least jokingly. Anyway, it would be hard to drive around with a giant opaque sheet on your robot.
"He said my name is Private Andrew Malone
If you're reading this then I didn't make it home
But for every dream that's shattered another one comes true
This car was once a dream of mine now it belongs to you
And though you may take her and make her your own
You'll always be riding with Private Malone" David Ball, "Private Malone"
Unread 01-03-2003, 21:53
sevisehda's Avatar
sevisehda sevisehda is offline
sevisehda is an unknown quantity at this point
Send a message via AIM to sevisehda
That idea come up as much as jamming enemy bots radio. I thought that in previous years there was a rule against such visually blocking devices. However most teams have said their sails are semi-transparent. Also a large portion of these sails deploy then retract for the remainder of the match. Keeping them open would be an invitation for an anemy bot to tear it with an arm.
Unread 09-03-2003, 15:38
mynameisalex's Avatar
mynameisalex mynameisalex is offline
#0677 (The Wire Strippers)
mynameisalex is an unknown quantity at this point
My team used large wings with black fabric, but that was planned only for making sure boxes went forward and didn't land on our controls. Then we discovered that it also blocked our opponents' vision when we were on top of the ramp, and we thought that was cool. I think it's OK, because we never parked right in front of the drivers; we stayed on top of the ramp. Their function was to protect the controls, while anything else was icing on the cake. Someone also got their revenge: our left wing had to be grommeted back together because somebody stuck a prong or something through it and tore it pretty nastily. It was cool, but far from indestructible.
An iguana, perhaps?
Unread 09-03-2003, 15:49
Our wings serve a double purpose: they're there to protect the controls, and the bottom frame is made of aluminum extrusion because we're a king-of-the-hill bot and have to hold our ground. We can't deploy them without the sail, so I think we're exonerated from any charges of viciousness or deliberately being nasty. Besides the fact that they're pretty...
An iguana, perhaps?
pic: 141's Robot stacking side view CD47-Bot Robot Showcase 7 28-02-2003 12:16
Image Discuss: 957 robot side view CD47-Bot Robot Showcase 5 14-02-2003 01:05
Opportunity for exciting view archiver 2000 3 23-06-2002 22:43
Good news for those who liked the old threaded view Brandon Martus Announcements 6 24-11-2001 21:22
