Go to Post I won't tar and feather you, I'll disagree though. - Andrew Schreiber [more]
Unread 29-12-2014, 14:59
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
Motorized Cart
I know this question will be asked again by the seniors and last year we erred on the side of telling them no, but I thought I'd put the question out there.
Is it against the rules to have a drive-able cart?
After our robot was shipped to World's last year they built a driveable robot cart. It has bumpers on it that stop it dead so if it bumps into anything it doesn't move. Basically it is a robot with a marine battery underneath the main robot. Doesn't take up anymore room than a normal cart it just has a seat where the driver would stand.
Last year the drive team were juniors and we told them "Better not risk it". This year is their last and I know they'd love to drive out there.
Unread 29-12-2014, 15:17
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Re: Motorized Cart
Motorized carts aren't illegal, as of 2014 rules. 2015 rules may vary.
That being said, it also depends on the venue, as well as space constraints. I would suggest if you're looking to build a motorized cart, implement some method of using the cart in a "neutral" gear so you can manually push the cart.
Academic Student (Forever)
Unread 29-12-2014, 23:35
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
Re: Motorized Cart
In 2012 and 2013 we used a motorized cart without any issues, though it is impossible to say for certain next year's rules will allow it.
Unread 30-12-2014, 00:02
Re: Motorized Cart
It is not against the rules, no.
However, there are other considerations than just the rules.
There's safety. There's crowded areas in the pits and around the field. And there's the tendency of field reset to move unattended carts into their parking areas.
You'll need a neutral gear at a minimum, for field reset to be able to move the cart if needed (or if the battery dies). I'd add a beeper and a light for crowds, and possibly replace (or upgrade) "bumper" with "rangefinder set to stop about 6" from obstacles".
Speaking of obstacles... Can it go over about a 3" hump without spilling its robot? Such humps aren't uncommon in arenas--they're usually wiring covers. What about through a standard doorway? Again, not an uncommon situation, robot going through a doorway on a cart (and having trouble...)
Just a few considerations that, in my mind, would relegate a powered cart to use outside of FRC competitions.
Unread 30-12-2014, 00:08
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Re: Motorized Cart
I know team 2013 had a driveable robot cart this year, maybe you could get in touch with them.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 30-12-2014, 00:36
Jpatterson1710's Avatar
Jpatterson1710 Jpatterson1710 is offline
AKA: Josh Patterson
FRC #1710 (Ravonics Revolution)
Jpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura about
Re: Motorized Cart
Team SWAT 1806 has had a motorized cart for a while. It seems to get around fine. The driver stands on it and drives it with a joystick. I've never seem them have any issues at regionals or champs.
2012-2014 Mechanical Team FRC 1710
2014-2015 Chief Operations Officer FRC 1710
2016-Present FTAA
