Go to Post Andy, you have daughters, would you buy them a Dave doll? - MissInformation [more]
Unread 30-12-2014, 18:18
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
836 Library Release
Most of it this been programmed using LabView 2014 so you probably won't be able to view or run it until Saturday.
Rather than releasing robot code, we're releasing a library this year. With examples even! Simply unzip the file and run "install.exe" and you'll be given a prompt for where to install the library and the examples. By default the library will install to user.lib and the examples will install themselves to the LV examples directory. If you have any issues or questions, please ask and we'll try to answer them. If something doesn't work, let us know and we'll try to troubleshoot. Some of these were written over the past few months and haven't been completely debugged.
Unread 31-12-2014, 11:50
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: 836 Library Release
Have you considered using VIPM to release this instead?
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 31-12-2014, 16:37
GuyM142's Avatar
GuyM142 GuyM142 is offline
AKA: Guy
FRC #3339 (BumbleBee)
GuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really nice
I have only went briefly over the examples, but can you explain why do you use the FIFO and config file vi's for?
How does it work?
Thanks.
Unread 01-01-2015, 00:36
One Eyed Man
I've looked at it but haven't had time to learn to use it.
How does it work?
Which FIFO and config VIs are you referring to?
