pic: 1086 Blue Cheese Legen-dairy Drive Mark4
Re: pic: 1086 Blue Cheese Legen-dairy Drive Mark4
Did you guys make any changes from last season?
The Gearbox is integrated into the frame, we are using 4 inch mecanum wheels, we used two Colson wheels per module instead of one, we are using 8 motors, and we are using retaining rings.
To add on to what John said:
1. When using 4 motors, it is lighter than last years system (It is actually geared so it will still work if we decide to not use the minicims) 2. It is now a single stage reduction rather than using a tough box nano. 3. The modules have gotten smaller because we are using 2 inch colson wheels. 4. The piston is now a 2 inch stroke rather than a 3 inch stroke with the ports rotated. This actually allows our frame dimensions to be much more flexible than last years design. 5. We had issues with last years system with the bolts on the modules backing out (especially at the rumble, where we had one bolt back out enough to prevent us from using the traction wheels after lunch). To fix this, we are switching to retaining rings. 6. The 4 inch mecanum wheel allow us to make the traction wheel even closer to the mecanum wheel, making the chain length even shorter. 7. The modules are now made out of 1/8th sheetmetal instead of 1/4th plate, allowing us to use our sponsors turret punch. This should be faster and more accurate than trying to manufacture it in house. 8. The frame has the battery box built in, in order to be more robust than last years system. Last edited by Electronica1 : 30-12-2014 at 18:00. Reason: remembered #8 |
What Alex and John said.
Although 1/8" material is pretty hefty, you're missing an opportunity to add essentially "free" stiffness to your frame members by only using L shaped metal pieces instead of "C" shapes.
I would recommend that you add a continuous bottom flange to every piece of sheet you have in this photo. Also, if you do what I mentioned above, you could certainly use a thinner gauge of metal (like .090"), which would allow you to have less lightening holes. Your turret punch sponsor will thank you. Last edited by AlecMataloni : 30-12-2014 at 18:40. Reason: clarifications |
#7
That's fair. I don't have much experience with mecanum. I didn't think about it initially, but now I recall hearing that having a flexible frame is important to making sure that all 4 wheels are contacting the floor.
#9
We have found this particular frame style to be more than strong enough for anything we will run into for frc. |
#10
It looks really slick, and I like it! |
#11
As for the cheese holes. We are Blue Cheese after all, it's a style thing ![]() |
#12
Does the extra cim on each of the front wheels provide an advantage over just a 4 cim drive?
#13
I believe there is a miniCIM along with a CIM on each corner.
#14
That's a great looking chassis.
Do you install your mecanum wheels as rendered? It's backwards from a normal set up. David |
#15
Yea, I put them back in when I was trying to clean up our cad model to post it, and mixed it up. We will fix it for the season if we chose to use this system.
