Go to Post My only question is, Can your robot place tetras and deliver Krispy Kremes to team mentors in autonomous mode? - Rich Kressly [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 30-12-2014, 17:00
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
Re: New AndyMark Products (Swerve & Steer module?)
The long cantilever on the bevel pinion worries me too.
I noticed that too. I did some quick calculations on the bending of the shaft under stall conditions and got .000187 max deflection. But keep in mind that's at the end of the shaft, not the mating surface of the bevel gear. So it seems the long cantilever shouldn't be a problem at all.
For those interested, the values I used to calculate the deflection are as follows:
.75 length of unsupported shaft
26.5 angle of pinon pitch cone
20 degree pressure angle
3/8" 4140 hex shaft
47 lbs radial pinon load under stall
145 in-lbs at pinon under stall
25 and 50 mm pitch diameters (from AM site)
-Adrian
Unread 30-12-2014, 19:53
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
Wow, I'm confident we could build this faster than our versa-chassis. I really love how it comes fully assembled, the drive train is something I want to touch as little as possible. Being able to purchase a replacement module and just swap it in is awesome.
2016: FRC 865 Mentor
Unread 30-12-2014, 21:38
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
8.2lbs is a little much, but still realy good with everything on it.
Are the gears steel or aluminum? Are there alternate gear ratios available?
I'm wondering if there's a way to remove the first stge of gear reductions without compromising anything. This could easily be made half a poun dlighter if that were the case.
EDIT: I can't see in the cad how the smaller bevel gear is constrained axially. Is there a shaft collar I'm missing?
DOUBLEEDIT: Same goes for the large bevel gear. It appears to only be constrained by a single e-clip and the wheel. And the wheel is not constrained.
Unread 30-12-2014, 23:00
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
I imagine it would be incredibly difficult to get it to weight any less...
PG-71: 1.9
CIM: 2.82 lbs
4" wheel: 0.31 lbs
However you slice it, you pretty much have to have those components for swerve (we wont go into variants that chain together steering... that invites a compromise situation that I don't think these modules were designed for). Those 3 parts alone total up to 5.03 lbs, which is 61% of the weight of the module.
Of course, there's always the discussion on where to spend your weight budget, and how advanced drive trains like swerve play in... but that's probably best left to a different thread
This looks like a pretty awesome solution. Personally, instead of a PG-71 for steering, I would have liked to see an attempt made to incorporate the Denso Throttle Motor... we've been allowed up to 4 of them in the past, yet I think they are the most under-utilized motor in FRC so far! Of course, using them would probably require a complete gear box design as well...
2016: Lake Superior WFFA
Unread 30-12-2014, 23:04
AdamHeard's Avatar
Lead Mentor
8.2 is fine.
Its a COTS swerve for $325. Thats a different set of design constraints than a team. Very difficult.
Unread 30-12-2014, 23:30
pwnageNick's Avatar
pwnageNick pwnageNick is offline
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
pwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond repute
A sensor on the back of the 775 with that much reduction after is going to be pretty sloppy imo.
I'm gonna second both of these concerns, especially the second.
FRC 2451: PWNAGE, Student/Team President (2009-2012)
FRC/VEX 2451: PWNAGE, Strategy/Design Mentor (2013-)
VEXU NAR: North American Robotics, Student/Chapter President (2013-)
Unread 31-12-2014, 00:04
asid61's Avatar
AKA: Anand Rajamani
FRC #1072 (MVRT)
8.2 is fine.
I love the design. $325 is absolutely incredible. Even custom swerves can cost more than that (for sure), and after seeing how many machined components are in this one I'm shocked they're not selling it at a loss.
8.2lbs was okay a few years ago, but we have seen lighter swerves from all over CD in the past few months (including a shifting version similar to this weighing in at 7lbs, and that one would survive a season as it was designed by PWNAGE) with this same basic design. Combined with the extra high COG of this module, I feel like it could be improved quite a bit. If a COTS swerve drive could compete with WCD in terms of weight, then it would be a pretty big improvement IMO. Of course I love swerve drives, so I'm more than a little biased here.
I'm looking at the CAD right now to see if there are any cheap improvements that can be made to raise the caster box up a level. It looks like it's filled with custom parts already (seriously, just look at it) so some different lightening patterns could really hack off a lot of weight. Plus, there's an extra plate that doesn't need to be there under the top plate.
Unread 31-12-2014, 00:15
AdamHeard's Avatar
Lead Mentor
Please design something lighter that could be made and sold for the same price then.
Unread 31-12-2014, 00:17
AdamHeard's Avatar
Lead Mentor
3/8" 4140 hex shaft
-Adrian
Don't forget mechanical slop, harder to model.
The slip fit in the being multiplied times that length is more appreciable.
Its probably fine, AndyMark knows their stuff... but it looks scary at first glance.
Unread 31-12-2014, 00:32
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Scott Kozutsky will become famous soon enough
This is going to be a blessing and a curse. I foresee many teams not prepared to do swerve doing swerve.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
Unread 31-12-2014, 00:40
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
we found out the limiting factoring to swerve is not making a module, but having the programming to control all 4 at once.
Unread 31-12-2014, 00:46
What aspect of the programming did your team find troublesome?
Unread 31-12-2014, 00:48
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
1339 will be staying away from swerve for the time being, even though so much awesome stuff has been released this year. We just don't want to get in over our heads and build a robot we can't compete with.
Unread 31-12-2014, 00:52
Darkseer54's Avatar
Darkseer54 Darkseer54 is offline
Former Controls Captain and Driver
AKA: Zach Kaplan
Darkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of light
Our team has very little programming support, and struggled with tuning a swerve. We understand that the math for it is online, and we use your math for our mecanum, but sensor integration and PID have been very difficult for us.
Unread 31-12-2014, 01:42
asid61's Avatar
AKA: Anand Rajamani
FRC #1072 (MVRT)
The thing is, I can't gauge the cost of making this. Please just take a look at the CAD; there are many custom parts that need to be CNC'd or even shaped.
Look at it this way: if you want something cheaper, then you can just take any old swerve drive and CNC all the parts from stock. Heck, might as well just make the encoders too, just for the lols. Sure, it's cheaper- technically. But there's no way of knowing how much their machine time is worth, and how long it would take to manufacture some of the more complex parts.
AM's design is fantastic in that it's also bulletproof, which adds to weight as a tradeoff. But I think it's possible to make it lighter without increasing the number of non-COTS parts, by using concepts laid out in (for example) Aren's recent swerve. I'll let you know if it's possible to remove that middle plate. My goal is to add one more part (made by a team or something) but decrease the weight by removing some of the other parts.
