Go to Post Its great for us as mentors to see students teaching other students and a robot being built from scratch without us. Maybe someday they won't need us at all!!! - DR3381 [more]
Unread 30-12-2014, 20:56
zakattacks's Avatar
zakattacks zakattacks is offline
Scouting Organizer, Webmaster
AKA: Zak
FRC #3250 (Kennedy Robotics)
zakattacks is on a distinguished road
Exclamation Internet at competitions
Hello, Sorry if this is in the wrong place, this is my first time posting on chief delphi.
I read the 2015 Administration Manual that was released a couple weeks ago, and I noticed something in section 4.14 Site Restrictions, that it says:
■ Do not arrange for Internet access or phone lines on the site or attempt to connect to the Internet.
Does this mean that we can't use our smartphones/data plans? Our team was planning to use laptops connected to the internet using 4g cellular cards (no wifi unlike, a hotspot), but we could use our smartphones if we had to.
What does this mean?!?!? Please help, this could blow our scouting system out the window!
Unread 30-12-2014, 21:13
Deetman Deetman is offline
AKA: Kevin Dieterle
Deetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond repute
Re: Internet at competitions
Generally, this rule means do not arrange for an internet service provider (ISP) to set up and provide internet access at the venue. I know this has been discussed in older posts here on CD, but it is pretty much impossible to prevent anyone from using their smartphone data connections at an event. Just don't set up a WiFi network, the field staff monitors the WiFi spectrum and will ask you to turn it off if you do set one up.
Edit: Also, some venues do not have a strong cellular signal. If you are dependent on a cell signal for your scouting system to work, I suggest having a backup plan just in case like local databases on your scouting system that can be merged together.
FIRST Mid-Atlantic Volunteer (2012-present)
Team 1014 Alumni (2004-2005)
Team 1712 Mentor (2011-2015)
Unread 30-12-2014, 21:35
zakattacks's Avatar
AKA: Zak
Thank you!
Unread 30-12-2014, 21:40
DonRotolo's Avatar
Back to humble
FRC #0832
You may consider using a wired hub or switch locally, and have just ONE data connection to the Internet. After all, likely not much data is flowing.
or do what we do: Bring the server too. Everything runs wired. Even the printer.
Unread 30-12-2014, 21:52
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
We do the same thing. The scouting computers run through an Ethernet switch which, while cumbersome, does mean we can have completely live data not reliant on any outside connections, which is pretty cool from a per-match strategy view. For something as important as scouting, there's no way I would want to rely on a 4G connection for a big chuck of the systems features (even though you could technically do it).
That being said, Bluetooth communications are not banned, so we're working to upgrade to that for the local system. Should be a LOT nicer to set up if we can make it reliable.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 30-12-2014, 22:55
JamieKilburn JamieKilburn is offline
FRC #0610 (The Coyotes)
Team Role: Driver
JamieKilburn has a spectacular aura aboutJamieKilburn has a spectacular aura about
While I didn't work on it personally, 610's tablet scouting program will save the match data to the local storage if it can't find a cell signal. If you're going to be in areas where service is spotty, I would highly recommend adding something along those lines into your program.
Unread 03-01-2015, 01:28
zakattacks's Avatar
AKA: Zak
Well thanks guys! my system is run mostly offline but for the little bit that does use the internet, I will tether my smartphone to a laptop and get an external antenna for the phone so service won't be much of a problem.
Unread 12-01-2015, 12:06
goofy173's Avatar
goofy173 goofy173 is offline
Electronics Mentor
FRC #2867 (ElkLogics)
goofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to all
I don't think anyone checked at several of the competitions I attended as when I searched for wifi signals, there were plenty. At Worlds, there were many. But banned is banned.
