Go to Post Pizza tastes best after a few long hours of robot building. - Max Lobovsky [more]
Unread 30-12-2014, 21:32
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
paper: Cyber Blue 234 Drive System Test - Performance and Power
Thread created automatically to discuss a document in CD-Media.
Cyber Blue 234 Drive System Test - Performance and Power by Chris Fultz
Unread 30-12-2014, 21:36
Rookie Year: 1942
Re: paper: Cyber Blue 234 Drive System Test - Performance and Power
This fall Cyber Blue completed a series of drive system tests to compare the acceleration, top speed, voltage drop and amperage for 4 different motor combinations and two robot operations.
We used a special built, kitbot chassis, 4 WD and tested with 2, 4 and 6 CIM and 4 CIM + 2 Mini-CIM motors. We tested with the robot "alone" for a 50 foot test run, and also pushing a 130 pound, unpowered, robot for a 25 foot test. The unpowered robot had a 4 CIM drive, with the Victors in "brake" mode.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 30-12-2014, 22:42
Knufire Knufire is offline
Thanks a lot for performing these tests! This is extremely useful data and will definitely be a significant factor in our drivetrain design next season.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 31-12-2014, 00:06
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
YES!
Thank you so much for releasing this data on CD. We will for certain use this to determine out drive train next year.
Unread 31-12-2014, 00:12
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Your data is enlightening. Thank you!
Unread 31-12-2014, 18:48
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
This is great!
I find it really interesting that on paper, the 4 + 2 CIMs are comparable, and sometimes beats the 6 CIM option.
Quick question, am I correct in assuming that the "Peak Amps - 1 Motor" for the 4 + 2 CIMS was a Mini-CIM? (as "Peak Total Amps" for 4 + 2 is higher than 6, but "Peak Amps - 1 Motor" is lower)
I'm not sure hard it would be to organise, but from that data I'd be really interested in seeing how more combinations of Mini-CIMs (say 2CIMs + 4 Mini-CIMs) stack up.
It seems that even though the CIMs are higher power, by operating the Mini-CIMs closer to their MPP they perform noticeably better. This implies that in some drive trains, Mini-CIMs would actually perform better than standard CIMs. However it should be noted that (assuming the same gearing form CIMs and Mini-CIMs) the closer you get towards the CIMs MPP, the closer you get to the Mini-CIMs stall condition.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 31-12-2014, 21:08
StephenNutt StephenNutt is offline
FRC #0172 (Falgor)
StephenNutt is an unknown quantity at this point
Very insightful. Thank you for putting together such a detailed paper and making it available to us all.
Unread 01-01-2015, 10:28
Rookie Year: 1942
Yes, in all of the test runs (3 trials) the mini-CIM was the highest amperage, but they were very close (44-47 Amps for at least one of the CIMs in each test). So while slightly higher, i think i would say "almost the same" given the accuracy of our data capture.
We plan to save the test chassis, and may do more testing next summer / fall to do more comparisons. With the CIM, mini-CIMs and "CIM adapters" for other motors there might be some interesting information to be found.
Chris Fultz
Unread 01-01-2015, 10:50
andytoennies andytoennies is offline
FRC #3061 (Huskie Robotics)
andytoennies is an unknown quantity at this point
This will certainly come in useful in just a few days when selecting our drivetrain. Thanks a bunch for saving us some major time.
Do you have any idea why the 4 CIM + 2 Mini-CIM configuration draws a similar current when pushing as the 6 CIM configuration? I seem to recall that Mini-CIMs are about 2/3 as powerful as a CIM, so it would seem to make sense if replacing 2 CIMs with 2 Mini-CIMs in this configuration, the total current drawn (at least in theory) would be reduced by about 11%.
Unread 01-01-2015, 11:06
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
Thanks for sharing this very useful data.
Knowing that the 4+2 combination is so close to the 6 CIM opens up options for motor allocation. Your report also provides good objective data for CIM speed under "real world" load conditions.
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at Standish and West MI in 2016)
FTC 6043 & 7911 (Competing at West MI and Allendale in 2015)
Unread 01-01-2015, 11:51
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
This is very interesting and useful. Now I'm really interested and seeing how this data changes as the gear reduction gets reduced and top speed rises. I know for many teams that use 6 CIM or similar drive trains it's to be able to get a higher top end speed without losing to much low end torque on a single speed gear train.
Our final ratio last year was 6:1 and I predict a 4 CIM drive struggling to handle that.
Unread 01-01-2015, 12:03
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
Very interesting study and thanks for sharing. I am a little surprised that the actual top speed is only about 75% of the theoretical top speed. I had assumed somewhere between 80 to 90% depending on gearbox and gear reduction.
Please don't call me Mr. Ed, I am not a talking horse.
Unread 01-01-2015, 12:30
Engineering Coach
What are you using to get the theoretical top speed? I ran the numbers quickly and it seems right to me. Theoretical top speed is around 11.65 fps (CIM at 5300 RPM and 4in wheels) and recorded for the 4 CIM is 10.76 fps which is 92%.
Unread 01-01-2015, 13:13
Rookie Year: 1942
i agree with Allen's math -
The total reduction is 7.95:1, counting the gearbox and the belt pulleys.
Theoretical = 11.63 FPS
4 CIM = 10.76 = 93%
6 CIM = 11.06 = 97%
To be more accurate, we would need the true free speeds of the CIMs and the actual diameter of the "4 inch" wheels with tread, but these are close.
Chris Fultz
Unread 01-01-2015, 13:43
Ed Law's Avatar
Sorry, I misunderstood what 37-42 Step Up mean. I also did not notice you published the final drive ratio which would have told me I did it the opposite way.
