Go to Post 5:20 - Lots of discussion about how FIRST pretty much wipes out the world of at least one object every year. - Andy Grady [more]
Unread 01-03-2003, 23:37
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
Switch with Servo
I was wondering i there was anyway to program a servo to be activated on a rocker switch instead of with a petentiometer, such as have it rotate 180 degrees or something?
Unread 01-03-2003, 23:44
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
servo = 127
if sw1 = 1 then servo = 254
if sw2 = 1 then servo = 0
Andrew Radamis
Programmer on 862
info@lightingrobotics.com
Unread 01-03-2003, 23:53
pras870's Avatar
AKA: Mike
#0870 (Team Rice)
you're positive this would work? i've been argueing with our programmer that it is possible.
Unread 02-03-2003, 00:47
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Originally posted by rust710
servo = 127
With this code, the servo will normally be in a centered position, and whenever the rocker switch is thrown, the servo will turn to the corresponding extreme. The servo will return to the centered position whenever the rocker switch is in its centered position.
If you would rather have the servo only go from one extreme to the other, you might want something more like this:
servo = 0
main_loop:
Unread 03-03-2003, 12:23
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
YEP...
We used just that to activate a "brake" pin in our gearboxes last year....works fine...
Don't PANIC!
S. P. A. M.
Unread 03-03-2003, 13:39
JLambert's Avatar
JLambert JLambert is offline
#0151 (Wild Cards)
JLambert is an unknown quantity at this point
Send a message via ICQ to JLambert Send a message via AIM to JLambert Send a message via Yahoo to JLambert
Originally posted by EricS-Team180
YEP...
Our team did the same thing two years ago, and we're doing it this year too. It works great.
Justin Lambert
02-03: Programmer Team #151
Unread 10-03-2003, 14:33
pras870's Avatar
AKA: Mike
#0870 (Team Rice)
we're using a rocker switch. Right now the code we have is this:
p1_wheel = 0
if p3_sw_aux2 = 0 then p1_wheel = 0
if p3_sw_aux2 = 1 then p1_wheel = 63
since the servo is on PWM 9 we're using p1_wheel variable, but yusing the roboemu program, the wheel on the joystick moves the server but not aux2, any help would be appreciated.
Unread 10-03-2003, 17:33
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
p1_wheel = 0
If you email me your code, I'd be happy to take a look. RoboEmu doesn't currently have any known issues that would affect code like the stuff you posted, so it's probably a line somewhere farther down overriding your code. Anyways, let me know. rob-bayer@mn.rr.com
Unread 11-03-2003, 09:56
pras870's Avatar
AKA: Mike
#0870 (Team Rice)
I also found out today that any wheel on a joystick controls p1_wheel, it's strange if you ask me.
Unread 12-03-2003, 02:53
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
Pras,
There's just not enough info to go on here. I suggest you do as Rob suggests, and send him your code. Better yet, post it here, and you can have a bunch more pair of eyes looking at it at the same time.
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
Using a switch before autonomous operation KZos550 Programming 11 04-02-2003 19:12
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
Changing gears archiver 2000 1 23-06-2002 23:26
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
