Re: SMD Soldering
When it comes to soldering especially at the component level you get what you pay for in terms of irons. The adjustable irons are useful but doesn't mean they are good quality. In my opinion good tips are far more important especially with the small SMD components. Most of the Wellers from Frys or Digi Key can do the job, just be sure replacement tips are available. There are a few models with tips that are difficult to find. If your doing a massive amount of surface mount parts you should look in to using solder paste and a heat gun/oven (don't use your oven in the kitchen, once you use a oven for soldering you should never use it for food again).
Re: SMD Soldering
Re: SMD Soldering
How pricey should the tips be? I just saw that the ones for the Hakko FX-888D cost around $10 or so. (2.4 mm chisel tip is $8.58)
Re: SMD Soldering
It depends on the name brand my Metcal uses $25-50 tips my weller at home uses $5 tips
Re: SMD Soldering
I've never done any SMD / SMT work myself, but folks who run a local hacker space do it all the time-- and they don't use a soldering iron:
http://tymkrs.tumblr.com/post/794649...nna-solder-smt |
Re: SMD Soldering
The way we solder our RN42s down, you probably don't need any fancy equipment. We put some double stick tape on the bottom and generously apply flux paste. This method works great for lining up but you can't be too overeager with the solder as the tape creates a small gap that can cause shorts underneath the board. The most important thing with SMD soldering is having the component lined up properly. As long as it is lined up, you shouldn't have any difficulties.
#7
Re: SMD Soldering
Flux, flux, and more flux.
For either through hole or surface mount the key to good solder joints is heat flow. One thing that can get in the way of heat flow is oxidation. Do you know what helps oxidation form? Heat, like all that heat in your soldering iron. That's why most solder that you buy is actually a tube with a goopy core of a chemical called flux. The flux melts as the solder melts and helps clean the joint of any oxidation, vastly improving the heat flow. I've seen a lot of people "paint" with the iron. That is, flowing some solder on the tip of the iron, and trying to spread that solder blob onto the joint. This doesn't work because all the flux in the solder has already burned off and none is left to clean the joint. This is why it is best to heat the joint with the iron and let the joint melt the solder. This ensures that the joint is at the proper temperature to melt and bond with the solder and allows the flux to do its job. However, this is difficult for surface mount components. You need a third hand to hold the small component with tweezers in addition to the iron and solder. Here is where flux paste or a flux pen comes in handy. First, apply flux to the pin and pad you want to solder. Then flow some solder onto your iron tip. Next, hold the part in position with some tweezers and paint the crusty blob of solder from your iron to the joint. The applied flux will magically breath life into that crusty solder blob and beautifully wick it on to the joint. With lots practice, you can solder QFP packages in no time with plenty of flux and the drag method: https://www.youtube.com/watch?v=erb6-i54tbo -David |
#8
Re: SMD Soldering
If you don't mind buying a used iron buy a metcal soldering iron (the ps2e power supply with hand piece and base can be had for around $100- $200 on eBay). The way the iron temperature control works is through the tip, so a brand new tip and you have essentially a brand new iron. The tips are a little bit more expensive (around $20 new) but you only need a few kinds and they last longer than any other iron I have uses.
As for soldering smd components just buy a good flux pen and make sure to use it. It will make a world of difference. Don't worry about getting a fine conical tip, as it will take forever to solder anything. You also won't be able to get enough heat down if you are soldering to ground planes. Instead buy a nice size (1/8") chisel tip and treat it with lots of care. Last edited by svenw : 31-12-2014 at 16:07. |
#9
Re: SMD Soldering
I do soldering almost daily at work. The link below is what I use, I just picked up a second unit for the team this week too. Had mine for over 3 years. No problems yet and I still haven't had to replace the elements.
http://www.gqelectronicsllc.com/come...idProduct=4393 |
#10
Re: SMD Soldering
For SMD parts, you could just make a reflow toaster.
Take a $20 toaster, a $10 Arduino clone, a $20 thermocouple, and a $10 relay. Or if you're cheap, a toaster and a seconds timer can work (although not as well as a real reflow oven will). |
#11
Re: SMD Soldering
I use one of these , it works great and usually comes with some extra tips. I like the soldering iron a little better than our Hakko F-888D and having the hot air rework is great for smd and other things like heat shrink, polycord welding .etc too.
We've also used a hot plate in a box to do some quick small batch reflow. Works quite well as long as you have a accurate thermometer to dial in temps. |
#12
Re: SMD Soldering
Honestly, I would shy away from the SMD toaster ovens. They're really just toys that kinda do the job. Heat distribution is terrible in them and even the metal grates you put them on can be disastrous. Plus, you still have to get stencils made, unless you want to try to put paste on the pads by hand (have fun with that).
#13
Re: SMD Soldering
I don't use the grate. I use a large metal plate that came with the oven, and that seems to do the job. For stuff like QFN I would be worried about proper positioning, but you can hardly solder those by hand easily either. I don't know about heat transfer, but I have done quite a few boards with my $20 toaster, including a sensitive high power LED board. With my shaky fingers I do not want to SMDs by hand (although I imagine it would involve a lot of cussing). |
#14
Re: SMD Soldering
Thanks for all the help so far, everybody! I never would have imagined that I'd get so many responses in less than 24 hours. |
#15
Re: SMD Soldering
http://www.ebay.com/itm/FULL-PACK-GQ...em3cc622 7884 |
