Go to Post Welcome to the world of pros and cons. - Billfred [more]
Unread 31-12-2014, 14:09
SquishyIce's Avatar
SquishyIce SquishyIce is offline
FRC #1405 (Finney Falcons)
Team Role: Electrical
SquishyIce can only hope to improve
Re: SMD Soldering
Originally Posted by Michael Hill View Post
Ya, this is important too. I like the wedge tips for SMD work. The conical tips they usually come with aren't usually very good. The chisel tips give you more contact with whatever you're trying to solder.
How pricey should the tips be? I just saw that the ones for the Hakko FX-888D cost around $10 or so. (2.4 mm chisel tip is $8.58)
Unread 31-12-2014, 14:19
anthonyttu anthonyttu is offline
Texas Instruments Engineer
AKA: Master Chief
FRC #5417 (Eagle Robotics)
anthonyttu has a spectacular aura aboutanthonyttu has a spectacular aura about
Re: SMD Soldering
It depends on the name brand my Metcal uses $25-50 tips my weller at home uses $5 tips
Unread 31-12-2014, 14:25
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: SMD Soldering
I've never done any SMD / SMT work myself, but folks who run a local hacker space do it all the time-- and they don't use a soldering iron:
http://tymkrs.tumblr.com/post/794649...nna-solder-smt
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 31-12-2014, 14:29
VacioArconte's Avatar
VacioArconte VacioArconte is offline
Appreciator of Robots
FRC #2468 (Team Appreciate)
VacioArconte is a jewel in the roughVacioArconte is a jewel in the roughVacioArconte is a jewel in the rough
Re: SMD Soldering
The way we solder our RN42s down, you probably don't need any fancy equipment. We put some double stick tape on the bottom and generously apply flux paste. This method works great for lining up but you can't be too overeager with the solder as the tape creates a small gap that can cause shorts underneath the board. The most important thing with SMD soldering is having the component lined up properly. As long as it is lined up, you shouldn't have any difficulties.
Unread 31-12-2014, 15:20
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Re: SMD Soldering
Flux, flux, and more flux.
For either through hole or surface mount the key to good solder joints is heat flow.
One thing that can get in the way of heat flow is oxidation. Do you know what helps oxidation form? Heat, like all that heat in your soldering iron. That's why most solder that you buy is actually a tube with a goopy core of a chemical called flux. The flux melts as the solder melts and helps clean the joint of any oxidation, vastly improving the heat flow.
I've seen a lot of people "paint" with the iron. That is, flowing some solder on the tip of the iron, and trying to spread that solder blob onto the joint. This doesn't work because all the flux in the solder has already burned off and none is left to clean the joint.
This is why it is best to heat the joint with the iron and let the joint melt the solder. This ensures that the joint is at the proper temperature to melt and bond with the solder and allows the flux to do its job.
However, this is difficult for surface mount components. You need a third hand to hold the small component with tweezers in addition to the iron and solder.
Here is where flux paste or a flux pen comes in handy. First, apply flux to the pin and pad you want to solder. Then flow some solder onto your iron tip. Next, hold the part in position with some tweezers and paint the crusty blob of solder from your iron to the joint. The applied flux will magically breath life into that crusty solder blob and beautifully wick it on to the joint.
With lots practice, you can solder QFP packages in no time with plenty of flux and the drag method: https://www.youtube.com/watch?v=erb6-i54tbo
-David
David Yanoshak
Co-founder REV Robotics | www.revrobotics.com
Unread 31-12-2014, 16:03
svenw svenw is offline
FRC #3683
svenw is a jewel in the roughsvenw is a jewel in the roughsvenw is a jewel in the rough
Re: SMD Soldering
If you don't mind buying a used iron buy a metcal soldering iron (the ps2e power supply with hand piece and base can be had for around $100- $200 on eBay). The way the iron temperature control works is through the tip, so a brand new tip and you have essentially a brand new iron. The tips are a little bit more expensive (around $20 new) but you only need a few kinds and they last longer than any other iron I have uses.
As for soldering smd components just buy a good flux pen and make sure to use it. It will make a world of difference. Don't worry about getting a fine conical tip, as it will take forever to solder anything. You also won't be able to get enough heat down if you are soldering to ground planes. Instead buy a nice size (1/8") chisel tip and treat it with lots of care.
Unread 31-12-2014, 16:22
Loxmyth Loxmyth is offline
FRC #3787 (4-H Ocosta Wild Robotocats)
Loxmyth has a spectacular aura aboutLoxmyth has a spectacular aura aboutLoxmyth has a spectacular aura about
Re: SMD Soldering
I do soldering almost daily at work. The link below is what I use, I just picked up a second unit for the team this week too. Had mine for over 3 years. No problems yet and I still haven't had to replace the elements.
http://www.gqelectronicsllc.com/come...idProduct=4393
Unread 31-12-2014, 17:01
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: SMD Soldering
For SMD parts, you could just make a reflow toaster.
Take a $20 toaster, a $10 Arduino clone, a $20 thermocouple, and a $10 relay. Or if you're cheap, a toaster and a seconds timer can work (although not as well as a real reflow oven will).
Unread 31-12-2014, 17:09
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Re: SMD Soldering
I use one of these , it works great and usually comes with some extra tips. I like the soldering iron a little better than our Hakko F-888D and having the hot air rework is great for smd and other things like heat shrink, polycord welding .etc too.
We've also used a hot plate in a box to do some quick small batch reflow. Works quite well as long as you have a accurate thermometer to dial in temps.
2016: FRC 865 Mentor
Unread 31-12-2014, 18:16
Michael Hill's Avatar
Re: SMD Soldering
Honestly, I would shy away from the SMD toaster ovens. They're really just toys that kinda do the job. Heat distribution is terrible in them and even the metal grates you put them on can be disastrous. Plus, you still have to get stencils made, unless you want to try to put paste on the pads by hand (have fun with that).
Unread 01-01-2015, 03:11
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: SMD Soldering
I have done the paste by hand. It's really not that hard for the standard types of smd stuff with legs and tiny resistors; just use a toothpick to apply. Unless you've got a ton of circuits to solder, in which case it makes sense to invest in a stencil.
I don't use the grate. I use a large metal plate that came with the oven, and that seems to do the job.
For stuff like QFN I would be worried about proper positioning, but you can hardly solder those by hand easily either.
I don't know about heat transfer, but I have done quite a few boards with my $20 toaster, including a sensitive high power LED board. With my shaky fingers I do not want to SMDs by hand (although I imagine it would involve a lot of cussing).
Unread 01-01-2015, 11:05
SquishyIce's Avatar
Re: SMD Soldering
This looks like a rather viable option. It also appears that the tips this unit uses are 900M (A rather standard size), so it would be easy to replace them.
Thanks for all the help so far, everybody! I never would have imagined that I'd get so many responses in less than 24 hours.
Unread 01-01-2015, 12:24
Re: SMD Soldering
I forgot to tell you, If you want free shipping, look for them on Ebay! Same company, same item.
http://www.ebay.com/itm/FULL-PACK-GQ...em3cc622 7884
Unread 01-01-2015, 16:09
Re: SMD Soldering
I find the most essential tool for SMD work is a good magnifier. I have used a binocular microscope in the past but I am using one of those dual magnifiers most of the time now.
http://www.mcmaster.com/#magnifiers/=va4pev
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Re: SMD Soldering
That is the normal cost for the genuine Hakko tips.
I actually just purchased one of these irons and let me tell you, after owning the one you said you have for years it was an absolute dream. You get fine temp control, a great iron holder, and tips that last, but the immediate difference I felt was the cord. Its extremely flexible, as opposed to the radioshack one, and will let you solder at whatever orientation you want.
Honestly I find soldering so relaxing now. Some people get a massage, I go into my basement and solder up a board...
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
