Go to Post Many would say it is both gracious and professional to make sure your robot will not damage another team's robot. - 4throck [more]
Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Unread 31-12-2014, 17:00
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Team 1726 button toggle & SR Latch code
We used these handy little utilities last year and I'd like to be able to re-use the code this year if it comes in handy again. Therefore I am posting the source VI code for other teams to use in the spirit of R13 for the 2015 game.
Button toggle allows the drive team to use a game controller button like a toggle switch. It detects the button press and flips the true/false state of the toggle output to turn something on or off as desired.
SR latch uses one button to set the output to true and second button to reset it back to false.
If you wish to clone multiple copies of these VIs in your code make sure to make them re-entrant to avoid confusion with shared resources.
Hope some other teams also find these useful.
Unread 01-01-2015, 19:21
nwall nwall is offline
It's a hardware problem
AKA: Nicholas
FRC #0418 (LASA Robotics)
nwall is an unknown quantity at this point
Re: Team 1726 button toggle & SR Latch code
Thank you for posting this. Our team has always done it one way (since I've been here) and haven't really thought about other ways of doing it because it worked. I do have a question about your "Button Toggle.vi", which is why you use the blocks used. (i.e. Not and And for "Pulse Out", Not and Select for "Toggle")
I have attached our version of the "Button Toggle.vi", which swaps out the two sets mentioned above with Greater Than and XOR. I ran a benchmark on both methods to compare the time required to do each operation 100 million times, and after taking the average of 25 runs, our method took ~1551ms to complete the 100 million iterations, with your method taking ~2000ms. I assume that this is because LabVIEW doesn't have to wait on the output from a block to put it into the next block, but I'm not sure.
For a competition, either would be plenty fast enough, so I'm just wondering why you do it this way.
Unread 01-01-2015, 22:38
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
For your benchmark, try setting your execution settings to preallocated clone reentrant, remove the checks for debugging, and add the check for inline and run it again. (see attached)
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 01-01-2015, 22:58
AKA: Nicholas
Thank you! I did that, and you're right, they both ran for an average of ~459ms. I've never really messed with the Execution settings too much, so would you recommend disabling debugging once the robot code is finalized and on the robot, or would the speed gained be negligible for the loss of debugging?
Unread 01-01-2015, 23:32
wt200999's Avatar
Texas Instruments
AKA: Will Toth
You shouldn't have to worry about it for the robot code since when you 'deploy' the code (at least by default) debugging is disabled. You can see that this is true if you look under the Advanced category for the build specification in the default robot project. In fact I would leave it in for most of your VIs so when you load your code using just the Run button, you can still debug as usual.
Inlining the VI will give you some small performance benefits at the expense of larger compiled code. Just this check box alone will change your benchmark results. It is good for small widgets like the ones in this thread. For the reeentrancy you just have to be careful depending on the VI.
Unread 02-01-2015, 00:02
AKA: Mr Tanguay
As a digital electronic technician (now retired) I am used to approaching these kind of problems at the lowest bitwise level. The use of the greater than comparison operator just seems wrong to me but that's just me. I must admit however that I had a "slap myself on the forehead" moment when I saw your elegant use of the XOR operator for the actual toggling of the output. I'm gonna use that one from now on.
Since Labview is an optimizing compiler, it will probably come up with a more efficient solution during compilation anyway.
Unread 02-01-2015, 00:07
AKA: Mr Tanguay
Thanks for your insight regarding the inlining. I missed that one.
Unread 02-01-2015, 00:31
AKA: Nicholas
Oh, okay. Thank you! I figured this was the case, but I wasn't sure, because I haven't spent enough time in the settings.
I assumed it was something like personal preference, but I was curious if there was something I didn't know about LabVIEW (turns out how to turn off debugging). Our previous programming lead showed me the greater than two years ago, and because it worked I've never really given it too much thought until today. Thanks for putting this up!
