Go to Post If FIRST is going to succeed in its goals, then we need to help it. - jcatt [more]
Unread 31-12-2014, 14:44
philso philso is offline
FRC #2587
Re: SMD Soldering
Originally Posted by Michael Hill View Post
Check out this video. It's got a pretty good intro into SMD soldering: http://www.youtube.com/watch?v=b9FC9fAlfQE
Dave give a very thorough explanation of how to solder SMD components.
Originally Posted by Jared View Post
It'll be harder with a cheaper radio shack soldering iron, but not impossible. What package are you trying to solder? Some are easier than others.
The easiest way to do SMD soldering without great equipment (IMO), is to put a bit of solder on one pad on the PCB, then solder one pin of your component to the pad. This may take a few tries to get the component lined up. Next, put way too much solder over all the pins so that they're all shorted together but soldered to the pads underneath. Finally, reheat with your iron, and use solder wick to pull away extra solder. That's how I do it with a 15 watt soldering iron I bought for $7 from radio shack.
With IC's, it works better to tack down two pins on opposite corners.
Originally Posted by ILAMtitan View Post
This one: http://www.hakko.com/english/products/hakko_fx888d.html
You can get it from Amazon, SparkFun, or Adafruit.
It has enough power to apply heat quickly and efficiently, and still maintain tip temperature. Ideally, you want to make the connection as quickly as possible so that heat isn't transferred into surrounding components. I usually solder PCBs at 750F, and haven't had any problems so long as the iron has enough heat capacity. You can easily swap the tips out on the Hakko for fine point work, or something bigger for through hole or large gauge wire. This will be the biggest difference for doing SMD work.
[ninja edit]Skip the hot air rework tools until your proficient at SMD work with the iron. Do some research so you know what a good connection looks like, and what you need to strive for. Once you have some hand on experience, you'll have a much more intuitive grasp of how the heat transfers and what would be easier with a hot air gun. [/ninja edit]
You can also get good deals from eBay on new and used temperature controlled irons. Look for Hakko 926, 936 or 937. Make sure you are getting the handpiece as well as the base. I find the newer Hakko's we have at work a bit flimsy.
An alternative to using the wire type solder is to purchase some solder paste that is loaded into a syringe. Make sure it comes with a plunger. Some of the solder paste syringes are meant to be used with automated equipment where the solder paste is pushed out by the machine. Squeeze out a tiny drop on each pad. Place the component on top of the solder paste and press down gently. The surface tension of the paste should hold the part in place. Heat up the pin/pad with the tip of the iron to melt the paste. Clean up with isopropyl alcohol (rubbing alcohol).
If you are going to be doing a fair amount of SMD soldering, you will eventually have to remove parts for one reason or another. It is easiest to remove two terminal SMD components using two soldering irons, one on each terminal (electric chopsticks). IC's are best removed by using two irons to "blob-on" enough solder to bridge all the pins on each side (as quickly as possible) and flicking the IC off the pads.
Unread 31-12-2014, 15:20
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Re: SMD Soldering
Originally Posted by VacioArconte View Post
generously apply flux paste.
Flux, flux, and more flux.
For either through hole or surface mount the key to good solder joints is heat flow.
One thing that can get in the way of heat flow is oxidation. Do you know what helps oxidation form? Heat, like all that heat in your soldering iron. That's why most solder that you buy is actually a tube with a goopy core of a chemical called flux. The flux melts as the solder melts and helps clean the joint of any oxidation, vastly improving the heat flow.
I've seen a lot of people "paint" with the iron. That is, flowing some solder on the tip of the iron, and trying to spread that solder blob onto the joint. This doesn't work because all the flux in the solder has already burned off and none is left to clean the joint.
This is why it is best to heat the joint with the iron and let the joint melt the solder. This ensures that the joint is at the proper temperature to melt and bond with the solder and allows the flux to do its job.
However, this is difficult for surface mount components. You need a third hand to hold the small component with tweezers in addition to the iron and solder.
Here is where flux paste or a flux pen comes in handy. First, apply flux to the pin and pad you want to solder. Then flow some solder onto your iron tip. Next, hold the part in position with some tweezers and paint the crusty blob of solder from your iron to the joint. The applied flux will magically breath life into that crusty solder blob and beautifully wick it on to the joint.
With lots practice, you can solder QFP packages in no time with plenty of flux and the drag method: https://www.youtube.com/watch?v=erb6-i54tbo
-David
David Yanoshak
Co-founder REV Robotics | www.revrobotics.com
Unread 31-12-2014, 16:03
svenw svenw is offline
FRC #3683
svenw is a jewel in the roughsvenw is a jewel in the roughsvenw is a jewel in the rough
Re: SMD Soldering
If you don't mind buying a used iron buy a metcal soldering iron (the ps2e power supply with hand piece and base can be had for around $100- $200 on eBay). The way the iron temperature control works is through the tip, so a brand new tip and you have essentially a brand new iron. The tips are a little bit more expensive (around $20 new) but you only need a few kinds and they last longer than any other iron I have uses.
As for soldering smd components just buy a good flux pen and make sure to use it. It will make a world of difference. Don't worry about getting a fine conical tip, as it will take forever to solder anything. You also won't be able to get enough heat down if you are soldering to ground planes. Instead buy a nice size (1/8") chisel tip and treat it with lots of care.
Unread 31-12-2014, 16:22
Loxmyth Loxmyth is offline
FRC #3787 (4-H Ocosta Wild Robotocats)
Loxmyth has a spectacular aura aboutLoxmyth has a spectacular aura aboutLoxmyth has a spectacular aura about
Re: SMD Soldering
I do soldering almost daily at work. The link below is what I use, I just picked up a second unit for the team this week too. Had mine for over 3 years. No problems yet and I still haven't had to replace the elements.
http://www.gqelectronicsllc.com/come...idProduct=4393
Unread 31-12-2014, 17:01
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: SMD Soldering
For SMD parts, you could just make a reflow toaster.
Take a $20 toaster, a $10 Arduino clone, a $20 thermocouple, and a $10 relay. Or if you're cheap, a toaster and a seconds timer can work (although not as well as a real reflow oven will).
Unread 31-12-2014, 17:09
mman1506's Avatar
mman1506 mman1506 is online now
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Re: SMD Soldering
I use one of these , it works great and usually comes with some extra tips. I like the soldering iron a little better than our Hakko F-888D and having the hot air rework is great for smd and other things like heat shrink, polycord welding .etc too.
We've also used a hot plate in a box to do some quick small batch reflow. Works quite well as long as you have a accurate thermometer to dial in temps.
2016: FRC 865 Mentor
Unread 31-12-2014, 18:16
Michael Hill's Avatar
Re: SMD Soldering
Honestly, I would shy away from the SMD toaster ovens. They're really just toys that kinda do the job. Heat distribution is terrible in them and even the metal grates you put them on can be disastrous. Plus, you still have to get stencils made, unless you want to try to put paste on the pads by hand (have fun with that).
Unread 01-01-2015, 03:11
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: SMD Soldering
I have done the paste by hand. It's really not that hard for the standard types of smd stuff with legs and tiny resistors; just use a toothpick to apply. Unless you've got a ton of circuits to solder, in which case it makes sense to invest in a stencil.
I don't use the grate. I use a large metal plate that came with the oven, and that seems to do the job.
For stuff like QFN I would be worried about proper positioning, but you can hardly solder those by hand easily either.
I don't know about heat transfer, but I have done quite a few boards with my $20 toaster, including a sensitive high power LED board. With my shaky fingers I do not want to SMDs by hand (although I imagine it would involve a lot of cussing).
Unread 01-01-2015, 11:05
SquishyIce's Avatar
SquishyIce SquishyIce is offline
FRC #1405 (Finney Falcons)
Team Role: Electrical
SquishyIce can only hope to improve
Re: SMD Soldering
This looks like a rather viable option. It also appears that the tips this unit uses are 900M (A rather standard size), so it would be easy to replace them.
Thanks for all the help so far, everybody! I never would have imagined that I'd get so many responses in less than 24 hours.
Unread 01-01-2015, 12:24
Re: SMD Soldering
I forgot to tell you, If you want free shipping, look for them on Ebay! Same company, same item.
http://www.ebay.com/itm/FULL-PACK-GQ...em3cc622 7884
Unread 01-01-2015, 16:09
Re: SMD Soldering
I find the most essential tool for SMD work is a good magnifier. I have used a binocular microscope in the past but I am using one of those dual magnifiers most of the time now.
http://www.mcmaster.com/#magnifiers/=va4pev
