Go to Post "There are two ways to compete in this world, you can drag your competitors down, or you can rise above them. Which is better for the world in the long run?" - Karthik [more]
Unread 01-01-2015, 14:33
andytoennies andytoennies is offline
FRC #3061 (Huskie Robotics)
andytoennies is an unknown quantity at this point
pic: 3061 Huskie Robotics Pre-2015 WCD
Unread 01-01-2015, 14:35
GarrettF2395's Avatar
GarrettF2395 GarrettF2395 is offline
AKA: Sierra 117
FRC #2395
Team Role: RoboCoach
GarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of light
Send a message via Yahoo to GarrettF2395
Re: pic: 3061 Huskie Robotics Pre-2015 WCD
Was this done in SolidWorks? If so where did you find the 2015 control system components? I've been needing to download them.
https://twitter.com/TeamNinjaMunkee
FRC 2395: Team captain 2008-2009, Design mentor 2010-2011, Lead design and strategy mentor 2012-Present
Unread 01-01-2015, 14:37
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
STEP files are available from Vex on the product pages of everything but the RoboRIO. RoboRIO CAD s available from NI; just Google "RoboRIO CAD"
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 01-01-2015, 15:58
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Scott Kozutsky will become famous soon enough
I'm pretty sure this isn't legal per 2014 rules (I don't know if it was supposed to be, besides "change is coming") given that the implied definition of "end" of a bumper is any corner.
4.6.8 R26
BUMPERS must be supported by the structure/frame of the ROBOT (see Figure 4-10). To be considered supported, a
minimum of ½ in. at each end of the BUMPER must be backed by the FRAME PERIMETER. Additionally, any gap
between the backing material and the frame
A. must not be greater than ¼ in. deep, or
B. not more than 8 in. wide.
This would mean that your side bumpers aren't properly supported. The definition may be grey enough to pass at some regionals but definitely not everywhere. Be careful.
http://www.usfirst.org/sites/default...ame_Manual.pdf
Aside from that, you don't need to use shaft collars for attaching encoders. Just drill a hole in any driven axle and shove the shaft of the encoder in there. (http://puu.sh/bSXmC/4694259cf2.jpg) Check the discussion here for more alternatives/experiences: http://www.chiefdelphi.com/media/photos/40864
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
Unread 01-01-2015, 17:41
4.6.8 R26
You're totally right, I had forgotten that the side "corners" of the hexagon would be considered ends. I am working on a quick fix right now, will update when done.
As to the drive encoders, I did not realize that that configuration was possible. I'll try that as well. Thanks for the suggestions.
Unread 02-01-2015, 06:24
Just completed the changes.
Here's the new bumper mount for the side corners:
Here's the new encoder mount:
