Go to Post I had a fight with my robot once during competition. I felt bad about it and apologized. - Tommy F. [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Thread Tools Rating: Thread Rating: 58 votes, 4.91 average. Display Modes
  #616   Spotlight this post!
Unread 01-01-2015, 16:46
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Re: 2015 HINT DISCUSSION
Originally Posted by 75vs1885 View Post
how did Andy Mark confirm the same fields as prior years?
AndyMark's new field was approved by FIRST for usage.
http://www.andymark.com/mobile/produ...p/am-2800.htm=
We are happy to announce that FIRST® has determined that this Field Perimeter has the ‘fit and function’ necessary for use in the 2015 FRC
  #617   Spotlight this post!
Unread 01-01-2015, 16:48
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Change is coming. The game piece will be pennies.
2012 - 2015 : 624 CRyptonite
Team Website
  #618   Spotlight this post!
Unread 01-01-2015, 16:56
Oblarg Oblarg is offline
AKA: Eli Barnett
RIP open gearboxes.
"The breakfast of champions!"
  #619   Spotlight this post!
Unread 01-01-2015, 17:05
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
Originally Posted by Oblarg View Post
RIP open gearboxes.
Not if you use a gearbox from those machines that turn pennies into elongated souvenirs.
  #620   Spotlight this post!
Unread 01-01-2015, 17:31
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Note that is not a confirmation that the field is the same as prior years. The field is modular so the only confirmation is that the interfaces where FIRST has made the year to year modifications in the past is the same. For example the 2014 field had the side boarders assembled in a "non standard" fashion so that the robot gate was in a different location. For 2013 there were two pieces of the side boarder that were not used to allow for the angled corners. Another example was that the 2014 field used a different top Polycarb retainers to account for the narrower field. In 2013 the two middle uprights were not used so the driver's station end would be narrower to accommodate the angled corners.
One of the changes that AM had to make before their field was approved was to change the side panel to driver's station interface to be compatible with the standard field.
So that means while a large portion of the field will be the same would could see another 8 sided field, or a field that has slightly different dimensions than 27x54 and the AM field could still be used.
  #621   Spotlight this post!
Unread 01-01-2015, 18:13
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
When did FIRST start using the clam shells for the KOP?
(I don't mean to make reference to anything that may or may not have happened , I'm just curious)
2016: FRC 865 Mentor
  #622   Spotlight this post!
Unread 01-01-2015, 18:50
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Capitalized letters spell out ICRRRRAMPF. It might be a bit of a stretch, but I see Icy Ramp.
Aim High played on the field surface from 2009.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
  #623   Spotlight this post!
Unread 01-01-2015, 19:36
Flimsor's Avatar
Flimsor Flimsor is offline
The Mad Cadder
FRC #1983 (Skunkworks Robotics)
Flimsor will become famous soon enough
Originally Posted by IronicDeadBird View Post
That could be possible, imagine the long box in KOP is a different surface with a bit less traction and what better thing to do on a slick surface then king of the hill!
I think if you set it up the right way, that would certainly make an interesting game.
- 2013
Thinking outside the box implies you have limited yourself in the first place.
Robots
  #624   Spotlight this post!
Unread 01-01-2015, 19:43
DohertyBilly DohertyBilly is offline
Team Role: Tactician
DohertyBilly is a glorious beacon of lightDohertyBilly is a glorious beacon of lightDohertyBilly is a glorious beacon of lightDohertyBilly is a glorious beacon of lightDohertyBilly is a glorious beacon of lightDohertyBilly is a glorious beacon of light
That was 2003
  #625   Spotlight this post!
Unread 01-01-2015, 20:35
gegozi gegozi is offline
gegozi is an unknown quantity at this point
Originally Posted by Msumat17 View Post
The game manual is only 65 pages this year, because when I go the the game manual link (on my iPhone at least) it says "0 of 65" for what page it is.
https://rps01.usfirst.org/frc/manual...-Encrypted.pdf
This is a substantial change compared to 93 pages in the 2014 manual. Could this be the change they are talking about?
Maybe you should consider the possibility that the encryption reduces the length...
  #626   Spotlight this post!
Unread 01-01-2015, 20:41
Maxwell777's Avatar
Maxwell777 Maxwell777 is offline
Is allowed to touch stuff now
AKA: Jackson Gray
FRC #0842 (Falcon Robotics)
Maxwell777 has a spectacular aura aboutMaxwell777 has a spectacular aura aboutMaxwell777 has a spectacular aura about
Originally Posted by Rangel(kf7fdb) View Post
I don't think that's quite right. If I understand, the issue is space and adding more teams per alliance wouldn't really allow for more teams at St. Louis.
Adding another team to each alliance would reduce the total number of matches, making events faster. However, time hasn't been much of an issue recently, or at least as far as I know.
But why?
  #627   Spotlight this post!
Unread 01-01-2015, 20:42
minch1396's Avatar
minch1396 minch1396 is offline
AKA: Emily Mincher
FRC #1396 (Pyrobots)
minch1396 is an unknown quantity at this point
my oh my.... change is coming...
There's been so many large robots! And the perimeter of the arena has changed before...BIG CHANGE = SMALL ROBOTS?
  #628   Spotlight this post!
Unread 01-01-2015, 20:46
Originally Posted by Flimsor View Post
What if the change is that there are no gamepeices? I'm really not sure hoe that would go, but it would certainly be a pretty big change. Maybe you manipulate something that's a part of the field? Maybe it's robot jousting and you get points by hitting opponents (in a non-damaging manner, of course).
No game pieces could mean robots skateboarding...
  #629   Spotlight this post!
Unread 01-01-2015, 20:53
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
Originally Posted by Ekcrbe View Post
Well, yes. Team 71 did it in 2002 (they're the robot coming in from the left), and that robot became one of the most famous in FRC history.
And, in addition to leveling the playing field, it could also rip it up, literally. With the huge requirement on traction that year, many teams (especially 71) ended up tearing the carpet pretty badly. FIRST changed the rules on what could be used for traction devices the following year.
https://www.youtube.com/watch?v=h4slvnvPHW8
That video has a better view of it walking & pushing at 00:18 and a real good close up of it walking at 00:23 (Can't see the Team # on the bot though).
  #630   Spotlight this post!
Unread 01-01-2015, 21:05
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
That is 71
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
