Go to Post I'll guess those tie-dyed, numbered balls are used for alliance-partner lotto. :D - Richard Wallace [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 01-03-2003, 13:38
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
Optical sensors with EduBot
Is there any good way to power a banner sensor/optical sensor with the EduBot? We could connect it in the same way that we would for the RC, but we are worried about whether the ground pin on the EDU-Rc could accept the 7.2 volts from the battery, instead of the 5 volts sent by the signal pin. The banner sensors work on 7.2 volts, but they do not work on 5 (6.6 is about the limit).
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
Unread 01-03-2003, 15:22
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
It's buried in this thread.
Unread 01-03-2003, 15:48
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
The Banner sensors just use current sourcing, so it should be safe just to hook the Brown and Blue wires up to the battery as you would normally, and put the white wire to the EduRobot digital input (+).
The manual says the sensors need 10-30V DC to operate normally, so you might need to use 2 9V batteries connected in series for this to work.
Basically:
1. Connect the (+) terminal of one 9V battery (Battery1) to the (-) of the other 9V battery (Battery2).
2. Connect the Blue wire to the unused (+) terminal on Battery2.
3. Connect the Brown wire to the unused (-) terminal on Battery1.
4. Connect the white (or black) wire to the (+) on the EduRobot digital input.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 01-03-2003, 16:41
The Banner sensors' outputs merely take the input pin to ground. They might like more voltage than the EduBot battery has, in which case you could lash up some 9V batteries, and feed the sensor(s) approx 18 V.
Unread 01-03-2003, 17:05
Go Badgers!
#0093
It's considerably more complicated than that, but basically that's what I said. If they did that, they would most surely damage the digital inputs.
The problem with this solution is that you are crossing batteries (feeding power from the 9V batteries into the NiCD battery). One pole will become depleted much faster than the other pole. Although this shouldn't lead to any problems, it isn't a very good practice.
Unread 02-03-2003, 10:05
No, you are not going to be "crossing batteries". The collector of the output transistor in the sensor is not connected to the sensor supply. The highest voltage in the circuit due to the sensor supply is at the base connection, typically 0.6 V above the common ground on the EduBot.
Essentially, the transistor is only a path for current from the input to ground, exactly like a relay contact (neglecting the saturation voltage of the transistor, around 0.2 V, typically). The sensor o/p is "isolated" from the the sensor supply, and run in a saturated condition, usually.
My comment that the sensor might like more voltage is based on the printed voltage requirements on the side of the sensor - "10-30VDC". Often, when connecting to counter-controllers (like the Omron H7BR I have recently been fiddling with), the sensor is connected to the controller's power supply which can be selected to either 12V or 24 V (in the case of the H7's). The designer of the sensor probably had a certain voltage range in mind for the circuit, and there could even be a regulator in the package to make the sensitivity setting repeatable.
The sensor might work at 7.5 +/- 1.5V from the NiCd, but the lessons learned may not be applicable to the Full-sized Bot. A trivial test with the IR sensors ("xxxD" not xxx"LV") shows that at 6 V, the "white piece of paper" detection range for the setting it was left at, is 1/2 the range of the same sensor at 15 V.
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
optical sensors acting strangely rosebud Electrical 10 03-02-2003 00:29
optical sensors majormusic2005 General Forum 1 28-01-2003 20:37
EDUbot Sensors marlon_jbt Robotics Education and Curriculum 11 19-12-2002 13:38
