Go to Post Relax. Have fun. Enjoy the improvements. Build what you want to. - Rich Kressly [more]
Unread 21-12-2014, 17:59
seth3206 seth3206 is offline
FRC #3206
seth3206 is an unknown quantity at this point
pic: 3206 Chassis on the Beach
Unread 21-12-2014, 18:00
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Re: pic: 3206 Chassis on the Beach
I love the render, Autodesk always seems to look so nice!
How are your 80/20 pieces attached to each other? I can't see anything in the render but I am assuming that there is some bracket on the inside corners.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 21-12-2014, 19:05
wyrzykowskij1's Avatar
wyrzykowskij1 wyrzykowskij1 is offline
FRC #2851 (Crevolution)
wyrzykowskij1 is an unknown quantity at this point
Are you at all concerned about bending your axle shafts during matches? What do you plan to use this for?
Unread 21-12-2014, 20:36
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
It looks like there is some kind of support right next to the wheel that should prevent this (look on the far side).
Unread 21-12-2014, 22:16
FRC #3206
There are 3/16 aluminum gusset plates on the bottom where the 80/20 pieces connect and two hole corner brackets on the outside part of the double wide pieces of 80/20 that spans the length of the robot.
Unread 21-12-2014, 22:21
FRC #3206
lopsided98 is correct, there are 3/16 aluminum plates that hold the bearings on both sides of the double wide 80/20. Some are hidden behind the wheels from this point of view.
Unread 22-12-2014, 08:06
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
This looks good. The render brings a new meaning to West Coast Drive.
1058 PVC Pirates 2016 - xxxx
Unread 02-01-2015, 11:23
FRC #3206
Here is the .stp file: https://drive.google.com/file/d/0B-z...ew?usp=sharing
