Go to Post At this point in build season, I'm thinking that whatever type we can get built and working is the best type, by far! - MrForbes [more]
Thread Tools Rating: Thread Rating: 29 votes, 5.00 average. Display Modes
Unread 01-02-2015, 11:59 AM
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Re: ANNOUNCING: navX MXP Robotics Navigation Sensor
Originally Posted by Conor Ryan View Post
This is the coolest Control System Add On ever. You can do so much with it, all without the danger of overloading the main CPU.
Looking in the Wiki here are the list of examples:That is pretty impressive, I can't wait to see what some teams can do with this.
Any videos of it in action?
Here's a video recently posted by the lead technical mentor of team 246, showing how they used the nav6 to implement field oriented drive. The navX is based on the same technology:
http://www.chiefdelphi.com/forums/sh...highlight=nav6
It's mentioned at about 5:30 and 10:30 into the video referenced in this post.
Unread 01-02-2015, 02:29 PM
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Just put in our order for one.
Team is excited to have a proper IMU on our robot this year!
Thanks, and good luck with the product!
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 01-02-2015, 03:05 PM
SpeedFreed's Avatar
SpeedFreed SpeedFreed is offline
Coach Annoyance Lead
FRC #0418
SpeedFreed is an unknown quantity at this point
I spent the large portion of my summer working with the Nav6 by Kauai Labs, and it was, by far, the easiest (and most accurate) gyro I had ever worked with. Ever. I never got around to using the other degrees (pitch, roll, linear acceleration), but it was worth it alone for just the yaw measurement, and it's easy integration into FOD. But that was just an offseason project, who knows what else tomorrow's challenge might allow us to do with it?
Needless to say, I already ordered one of the navXs, and you can be sure it will be on our robot next year.
Unread 01-02-2015, 03:15 PM
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Because this is an "active" roboRIO expansion module, my understanding is that it needs explicit FRC approval before you can use it on your robot. Does the navX have this approval?
Unread 01-02-2015, 03:18 PM
It only needs approval if you plug in a motor controller or servo to it.
Unread 01-02-2015, 03:29 PM
craigboez's Avatar
Mechanical Engineer
Thanks Joe. That would explain the lack of PWM outputs.
Unread 01-02-2015, 03:42 PM
Software Mentor
AKA: Scott Libert
The navX does support PWM/Quad Encoders as well as standard GPIO. These pins are direct pass-throughs from the MXP Connector, so whatever RoboRIO drives out those pins is routed to the navx MXP Digital I/O connectors.
Any announcement regarding legality as an active device can only come from FIRST, who has indicated that all approved devices will be listed in this year's game manual, to be released tomorrow.
Unread 01-02-2015, 03:47 PM
craigboez's Avatar
Mechanical Engineer
Are there any restrictions or recommendations on how to mount the roboRIO? Is vertical ok?
Unread 01-02-2015, 03:52 PM
REVving up for a new season
FRC #2848 (All-sparks)
I can't speak for the orientation requirements of this board, but you could always use a cable to relocated it off of the roborio.
http://www.andymark.com/product-p/am-2997.htm
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 01-02-2015, 03:54 PM
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
It also looks like it can be connected over USB, which would make it even easier to mount it away from the roboRIO.
Unread 01-02-2015, 05:35 PM
Software Mentor
AKA: Scott Libert
Connection over USB is definitely doable; but do note that the navX MXP RoboRIO I/O expansion capability is only accessible when navX MXP is connected via the MXP connector.
One interesting side note is that navX MXP can be connected *simultaneously* by both MXP connector AND USB. So you can access the navX MXP over the MXP Connector from your robot software and simultaneously monitor the navX MXP over the USB connector. There's a PC-based application called the navXMXPUI, more info on the Wiki (https://code.google.com/p/navx-mxp/wiki/navXMXPUI).
The navXMXPUI is really helpful to understand the full breadth of what the navX MXP can do, and should also help debug as you integrate the navX MXP into your robot.
Unread 01-02-2015, 04:00 PM
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Our alpha and beta testing of the rRIO included vertical mounting and we had no problems with it's orientation.
"A genius is just a talented person who does his homework" T. Edison
Unread 01-02-2015, 04:02 PM
Dartmouth 2020
AKA: lopsided98
Are you talking about the navX, or simply the roboRIO by itself.
Unread 01-02-2015, 03:55 PM
Software Mentor
AKA: Scott Libert
I'd definitely recommend horizontal alignment with the chassis.
We've put a decent bit of thought, though, into alternate mounting strategies.
Please take a look at the following wiki page and hopefully it provides enough detail regarding these alternate solutions:
https://code.google.com/p/navx-mxp/w...InstallOptions
You might want to consider the "One-wire connect via Floppy-disk Extension Cable" option and the "One-wire connect via USB Cable" options.
We were able to order some of the "Floppy-disk Extension Cables" on Ebay, and another poster just indicated that AndyMark is carrying them, as well.
Unread 01-02-2015, 03:58 PM
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
2 questions:
How much testing has this board undergone with the RoboRIO, outside of a Great like Joe Johnson?
The website shows 11 available. Is that true? Seems a bit low.
