Go to Post While searching is not as glamorous, I'm certain you could find a lot of good resources related to this topic. - Katie_UPS [more]
Unread 02-01-2015, 20:25
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
Re: Championship 2015: 8 Divisions, 600 Teams
Originally Posted by DonRotolo View Post
4 dimensions.
Um, seriously: The dome floor is huge. 8 fields fit easily. (use paper cutouts if you wish to check).
I would imagine 2 fields along the long direction of the dome would both be visible for a majority of the seats along that side.
Likely the Einstein fields will not be pristine, but used. Doesn't take much to go over everything carefully and bring it almost back to perfect. Unless 25 tears up the carpet again...
I don't know, that's a lot of fields. Five last year wasn't exactly tight, but doubling it up to ten fields? They may have to pull the lower level of the bleachers back in to make room, thereby using more of the seating up top.
"Measure with a micrometer, mark with chalk, cut with an axe."
