Go to Post How about "Lebron"? Wait, no, you'll be dooming yourselves to failure the last 30 seconds of every match. - Travis Hoffman [more]
Unread 02-01-2015, 21:17
Ideal_Nerd's Avatar
Ideal_Nerd Ideal_Nerd is offline
Team Caption
FRC #3591 (Wild Warbots)
Team Role: Driver
Ideal_Nerd has a spectacular aura aboutIdeal_Nerd has a spectacular aura about
pic: Team 3591 2015 Drive
Unread 02-01-2015, 21:19
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
Re: pic: Team 3591 2015 Drive
Why are you using 1/4th inch? If you are putting bends in it, just go 1/8th inch, it will be lighter and strong enough to go through anything frc will put it through.
Unread 02-01-2015, 21:28
Ideal_Nerd's Avatar
Team Caption
Team Role: Driver
We used 1/8 last year and it got beat up and our frame bent in on its self. We also probably cut a triangle pattern in to it to save weight. As of now if we switched to 1/8 we would save 8.6 lbs
Evan
Team Captain, CAD leader FRC team #3591.
Westerville Ohio.
Unread 02-01-2015, 21:30
Ideal_Nerd's Avatar
Team Caption
Team Role: Driver
Also here is the STEP file for anyone who is interested.
https://drive.google.com/file/d/0B_7...ew?usp=sharing
Evan
Westerville Ohio.
Unread 03-01-2015, 02:17
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
I'm probably going to be the first of many to say that with the right type of bends in the right places using the correct alum alloy, You do not need to use 1/4" alum, or even 1/8" alum. If you have a chance, check out some of 148s CAD. 148 has been doing sheet metal for a long time and I am sure you can learn a lot from it. I sure did.
Give this a look. https://docs.google.com/document/d/1...P1uGkje3U/edit
This is from Team 148 the Robowranglers
You sure are on the right track, just keep up the hard work!
