Go to Post These two options can both be used effectively to create a wonderful experience for the students, but limiting them to one area is like taking a globe, slicing it in half, and saying, "You can only explore this half." - Alex Golec [more]
Unread 27-12-2014, 12:01
jwhite jwhite is offline
FRC #2823
jwhite is an unknown quantity at this point
Team 2823 Raspberry Pi Experimental OpenCV C/C++ code
Hi Folks,
Our team used a Raspberry Pi for vision processing last year. The student ended up with code that had pretty poor performance; about 1 frame per second. In the off season, I and a few students spent some time working up code to explore the performance and try to optimize the code.
We've got a body of code I thought I'd share. I'm afraid it's not complete, and it's really only suitable for someone with a strong C/C++ background.
The code is all on GitHub here:
https://github.com/Team-2823/vision2
It has one novel useful feature - I rewrote the OpenCV capture function in C, with a built in color filter capability, so in theory we can get a frame in more rapidly than any other way. (Although frame capture turns out not to take that much of the time; it's things like canny and finding contours that are expensive). It does have a lot of other features; timing of functions, configurable functions to perform (e.g. blur, canny, contours, fast, and so on), and tuning for color and camera filters.
But it's more of a toolbox; it's not at all a ready made set of vision code, and really suitable to someone who feels pretty comfortable in C and C++.
At any rate, I figured I'd share instead of just sitting here refreshing the kick off countdown timer... <grin>.
Cheers,
Jeremy
Unread 27-12-2014, 22:49
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
Re: Team 2823 Raspberry Pi Experimental OpenCV C/C++ code
Very audacious. I will comb through this and see if my limited C/C++ experience can tell me what's happening. The electrical part of my team might find this interesting.
Unread 02-01-2015, 10:48
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
looks very clean. How do you plan to communicate between the roboRIO and the RPi?
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 02-01-2015, 10:52
FRC #2823
That's a different exercise <grin>. Last year, we just set a gpio pin to on/off if it was hot or not, although we did have a student write a network transport layer.
Cheers,
Jeremy
Unread 02-01-2015, 11:59
AKA: Michael Shires
FRC #0384 (Sparky)
hmm, neat. If you're interested, I actually have some experience setting up a TCP/IP communication between an RPi and a linux PC. Albeit different from a roborio, but the similarities are there. I'd love to help you out on this if you want, I may try and convine my team to use an RPi this year. They are awesome
Unread 02-01-2015, 21:50
anthonyttu anthonyttu is offline
Texas Instruments Engineer
AKA: Master Chief
FRC #5417 (Eagle Robotics)
anthonyttu has a spectacular aura aboutanthonyttu has a spectacular aura about
Would it not be faster/more efficient to use SPI or I2C directly to the roboRIO instead of trying to use already in use TCP/IP.
Unread 02-01-2015, 22:41
AKA: Michael Shires
FRC #0384 (Sparky)
Very probably xD However, my electrical knowledge is much lesser than my software. TCP/IP would be my goto comm setup, but I2C would likely be more efficient.
