Go to Post There were no heroes on the team, just everyone doing their part. - nuggetsyl [more]
Unread 02-01-2015, 22:56
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: Sparky 384: Custom DS Transmission (2014 Offseason Project)
Can you give me the total weight of this gearbox?
Unread 02-01-2015, 22:58
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
Very light. I'll wait for Brooke to chime in on this one as I don't know the specifics, but due to the cheesing (HA!) I want to say around ten pounds.
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 02-01-2015, 23:37
Fearthewookie's Avatar
Fearthewookie Fearthewookie is offline
AKA: Brooke Merritt
FRC #0384 (Sparky 384)
Fearthewookie is an unknown quantity at this point
Hello,
I cant say exactly due to the fact that my memory is horrible, but I will weigh it hopefully tomorrow and get back to you. I do know that it is less than you would expect it to be, I was surprised at it.
FLASH! AHHHHH!
Unread 02-01-2015, 23:41
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Originally Posted by dellagd View Post
Looks great guys!
Maybe this is the normal practice, but I hadn't thought to group all of the Powerpoles for all three motors into one connector before. Very tidy.
Tidy, yes. However, large banks of powerpoles are also much more difficult to plug and unplug.
Unread 02-01-2015, 23:46
AKA: Brooke Merritt
This can be true but we dont have too many issues with it ourselves (the largest powerpole bank we use is the one you see in the picture). The main problem with those Anderson powerpoles is installation xD They can be a real pain.
FLASH! AHHHHH!
Unread 03-01-2015, 00:06
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Originally Posted by Fearthewookie View Post
Hi Madison,
Im not sure I understand, which specific groove on the output shaft? Why does this worry you?
Thanks
I'm speaking of the innermost of the two retaining ring grooves turned into the output shaft. Folks will often put two retaining rings onto a shaft if they're training to constrain something axially, which appears to be what you're doing here.
The retaining ring groove, though, is a point of stress concentration in the shaft. You're presumably transmitting torque through the groove -- perhaps to a wheel or set of power transmission components -- and doing so can lead to a failure of the shaft at the groove.
--Madison--
...down at the Ozdust!
Unread 03-01-2015, 02:01
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
Looks pretty neat. Is the encoder mount and custom output shaft stuff the only change to the normal WCP gearbox?
Unread 03-01-2015, 07:43
AKA: Brooke Merritt
Hello,
No, it isnt. We did base the hole patterns off of the WCP gearbox so that way we can use the same gear ratios available COTS (saves time and money), but some of the geometry is different (the overall dimensions are different and the plates themselves are different). Our custom transmission is shorter and a little bit thicker than the WCP DS. The way our transmission mounts onto the 1" x 2" tubing is also different. The tolerances on the pressed bearings have also been changed to allow for a much better fit (no way those puppies are coming out). Some changes will also be made after kickoff to allow for motors and their pinion gears to be swapped out without having to take apart the transmission (something that is an issue with the WCP gearboxes). If you closely compare the two the differences will start becoming more apparent.
Thanks
FLASH! AHHHHH!
Unread 03-01-2015, 07:45
AKA: Brooke Merritt
Hi again,
I understand what you are saying now. Thank you for your input.
FLASH! AHHHHH!
