Go to Post Part of Gracious Professionalism is the Professional bit. Doesn't matter if you're a volunteer or a staff member, a failure of this level in the real world would result in getting fired. - [more]
Thread Tools Rating: Thread Rating: 39 votes, 5.00 average. Display Modes
Unread 03-01-2015, 05:06
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
OpenCV for RoboRio - Release
OpenCV For the RoboRio - Release
A few hours before kickoff and were finally able to release this. We have been working very hard to provide a working OpenCV
solution for everyone that not only supports the Axis IP camera we all have, but also the Microsoft HD 3000 USB webcam.
Our github page has everything to help you get starting using OpenCV, including our 2014 vision code which we used throughout
the 2014 season for hot target detection. The example supports reading images from a USB camera, Axis IP camera, or from
a file, by simply changing command line arguments
We have successfully ran this code on The RoboRio, and on a beaglebone black, so you can pick your poison. We also have this running
on the Tegra TK1, and will release a how-to on that very soon.
The OpenCV version we are providing is version 2.4.10 which we then patched to support the various camera settings of the
MS HD 3000 camera. It will also support other USB cameras although we havent tested it. And of course it supports the Axis
IP cameras.
The OpenCV libraries have been cross compiled using GCC 4.6.3 and has VFP_V3 and NEON support.
Some of the options it was compiled with:
TBB, FFMPEG, GSTREAMER, JAVA Bindings, JPEG, VL42, GTK
Java bindings means you can use this in Java as well, although we never tested it, so please report back if you do use it in Java.
Our github page has everything to help you get set up using C++ (Even though we program our Robot in Java, we program our Vision in C++).
Please let me know if you have any questions, we are here to help.
Link to Release: https://github.com/Team2168/2168_Vision_Example
The Program will take an input image like input.jpg (provided by the camera) and produce an output like that of output.jpg.
Regards,
Kevin
Happy New Year, and Happy New Season
And as always, if this is what you were waiting for, please provide you thoughts or any feedback you may have
ID:	17715  Click image for larger version
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 03-01-2015, 06:41
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
Re: OpenCV for RoboRio - Release
Looks very cool, we'll definitely try the java bindings out. How's the performance on the RoboRIO?
Unread 03-01-2015, 07:03
Controls Engineer
AKA: Kevin
not too bad actually... we started doing more controlled vision performance tests a few weeks back, but then that got pushed behind some other priorities.
Our original tests were documented here: http://khengineering.github.io/RoboR...on/cameratest/
and still hold some valid data, however, the new openCV libraries we just produced are a bit more streamlined and should run a little bit faster.
It is too early to give a good recommendation on the Rio's performance, but we have been able to get 320x240 at 15fps without any lag using the axis camera under 2014 game scenarios, and that was more than what we needed for last years game.
Everything we have done so far shows that the IP camera outperforms the USB HD 3000 Camera on the Rio, but I don't want to official state that as of yet until we do more controlled observations. We should have a new set of comparative data by the end of week 1 for both IP and USB cameras.
The main page where that information will be held is at http://khengineering.github.io/RoboRio/faq/vision/
Unread 03-01-2015, 07:53
Jared's Avatar
Jared Jared is offline
Awesome work. I've been planning to attempt to compile OpenCV on the roboRIO itself once we finally get one, but this seems like a better way.
Unread 03-01-2015, 10:18
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond repute
Wow. Looks really well done and documented. We'll definitely be using this as a resource this season. I'm assuming there will be some vision challenge this year given the Microsoft camera beta testing.
Good work.
Unread 03-01-2015, 17:48
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Good to know it works! We've got numpy packaged for the RoboRIO in opkg format, so OpenCV will probably next on the list of things to package.
Unread 06-01-2015, 01:02
mikhail's Avatar
mikhail mikhail is offline
AKA: Mentor of The Software ERRORs
FRC #3130 (ERRORS)
mikhail is an unknown quantity at this point
Thanks Kevin! This is really valuable resource you have created.
While our whole team is brainstorming and prototyping I've been "secretly" toying around with the control system. What I've achieved so far is: I cloned the 2168_Vision_Example project from GitHub, successfully built it in Eclipse with the arm-frc-linux-gnueabi toolchain. Then transferred the libraries and the binary onto roboRIO and successfully executed it in there. All the how-to steps are clearly documented in the project's README.md file. Thank you very much, Kevin!
Next will be to modify the 2168's code until it breaks and then start prototyping something my own
Unread 13-01-2015, 04:57
Wazzaps Wazzaps is offline
FRC #1573
Wazzaps is an unknown quantity at this point
Any way to do some processing with opencv and then display the results in the dashboard? (Processed image stream)
PS. We are using java.
Unread 15-01-2015, 19:20
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
I just tried this out today using the Java libraries and I got it to work.
After installing OpenCV to the roboRIO via the instructions on GitHub, I had to do some more work to make it work in Java.
First I had to add:
<var name="classpath" value="${classpath}:/path/to/opencv-2410.jar" />
to the end of the build.xml in the robot code Eclipse project (add it just before the closing </project> tag). This includes the OpenCV classes in the jar file that is uploaded to the roboRIO.
To load the native library in the robot code I had to add this line:
System.load("/usr/local/lib/lib_OpenCV/java/opencv_java2410.so");
Put this somewhere where it will get executed before any OpenCV code (ie. static initializer). The path will obviously be different if you installed OpenCV somewhere else on the roboRIO.
I was able to capture and stream an image from the Microsoft Lifecam HD3000, but it is at a very low resolution and I can't seem to change it. The same code works fine in Linux on my laptop. I'll see if I can figure more out tomorrow.
Unread 16-01-2015, 14:26
Corvo's Avatar
Corvo Corvo is offline
FRC #2846 (Fire Bears)
Corvo is an unknown quantity at this point
I'm currently running two versions of openCV in eclipse, the official 2.4.10 version and this one, and I've installed the java version (for both) as descrbied here. For some reason I'm getting an error with your version that I'm not getting with the 2.4.10 version from opencv.
It appears that this librabry only runs in 32 bit java and not 64. Is there any way to fix this without having to reinstall 32 bit java?
Unread 16-01-2015, 16:07
Controls Engineer
AKA: Kevin
First I had to add:
This is awesome news. I haven't had the time to test out Java myself (it is 1 item on a long to-do list of mine, but glad to hear it is working for you.
If you are having trouble changing the camera settings, try using the patch we added to OpenCV, we modified some of the v4l calls and exposed a new constructor to the videoCap class.
You can work off of the C++ example here: which will allow you to set FPS, image size, and some quality settings.
https://github.com/Team2168/2168_Vis....cpp#L633-L664
Let me know if this works for you or not.
Unread 16-01-2015, 16:12
Controls Engineer
AKA: Kevin
Are you trying to run this on your desktop or on a Arm based processor?
The OpenCV libraries we provide are for Arm based processors only so they will only run on a RoboRio, Beaglebone etc or anything running ArmV7 soft eabi. They will not run on an Intel based processor.
Please provide more details of where you are trying to run the program (causing the error), and what you have done thus far getting up to that point so that we can try to help figure it out.
Thanks for trying this out.
Unread 19-01-2015, 17:10
JagCode's Avatar
JagCode JagCode is offline
Bring Your &quot;B&quot; Game
AKA: Noah
FRC #2929 (JagBots)
JagCode will become famous soon enough
So, this happened. Not sure what went wrong. :I
We followed the instructions, and the Rio_Beagle directory was successfully created. However, the main.o that was inside was corrupted to kingdom-come.
Unread 19-01-2015, 17:44
Dartmouth 2020
AKA: lopsided98
I don't think main.o is necessarily corrupted, it is a binary file so you shouldn't be trying to open it with a text editor.
Unread 19-01-2015, 18:03
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Team 2481 is trying to get this working with our C++ project. Our project settings are what was generated by the FRC C++ plugin.
I'll admit that we don't have a lot of expertise when it comes to modifying the build/compiler/linker configuration.
We followed the instructions in the readme. The sample project compiles but when when we try to add the libraries to our project we aren't able to compile. I'm including the build console and our .cproject file.
Any assistance would be greatly appreciated.
Thanks,
Team 2481
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
