Go to Post Sleep?! How am I supposed to do that with the build season done?! There are still practice bots to make! - [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 03-01-2015, 12:37
BryceKarlins's Avatar
BryceKarlins BryceKarlins is offline
Video Production Junkie
FRC #1261 (RoboLions)
Team Role: Electrical
BryceKarlins is on a distinguished road
Re: 2015 Recycle Rush Scoring
I couldn't find anything in the rules (haven't read entire thing tho), can we open the totes and stack them inside of each other?
Unread 03-01-2015, 12:39
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
G16 Blue Box, Item C.
Unread 03-01-2015, 12:40
ATannahill ATannahill is offline
AKA: Alex Tannahill
Originally Posted by 216Robochick288 View Post
Grey totes aside, lets look at the gold ones. lets have 0 be a golden tote and ___ be the ground. Ill give you the situations I see happening.
___0___0___0____ =?
.....0
___0________0___=?
...0
...0
__0________=?
How many points would each situation be worth in auton? Would it be 6 (2 points each) on the first, or 18 points, 6 per.
Would the second be worth 20+6 (one stack one alone)? 20+2(this would be if scoring totes alone in auton are only worth 2)?
Would the last only be worth 20? It seems like quite a feat to get 3 stacked in auton. Im sure we will see it, but it seems insignificant if you look at what you can score after Teleop starts.
Assuming this is in the auto zone, they would be worth 6, 6, 20.
Please read page 19 of the manual.
216Robochick288's Avatar
216Robochick288 216Robochick288 is offline
Hopelessly Addicted to FIRST
AKA: Abby Wilson
FRC #0216 (RobodawGs 216/288/244)
216Robochick288 is a glorious beacon of light216Robochick288 is a glorious beacon of light216Robochick288 is a glorious beacon of light216Robochick288 is a glorious beacon of light216Robochick288 is a glorious beacon of light216Robochick288 is a glorious beacon of light
They are intended to be closed- THey are zip tied shut.
216/244/288 for life
"I want you to lose [by] the most you can!" ~Mr. Hepfer at Breakaway Champs. [Curie Match 100]
RoboDawg Alumni, 2009-2012
FIRST mentor 2010-?
FLL 2010-2012,2015-2016 FRC teams 857, 2586, 5486, and 5989 2013-?
For lack of being allowed to put them up top here are all my kids!
Unread 03-01-2015, 12:42
rjmah rjmah is offline
rjmah will become famous soon enough
I originally thought the coopertition points were a red herring since they won't really affect ranking since averages are calculated to 2 decimal places but the high value of the stacked totes probably means each alliance should try to put two yellow totes on the step once it is clear of grey ones. Assumes another robot will complete the stack of 4.
Robert Mah
Team 1246 Agincourt Lancers
Unread 03-01-2015, 12:43
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
You're forgetting a situation:
......0
___0 0________ = ? (I believe this is a void configuration resulting in 6pts,
however there was not an example given to this
situation in the manual.)
anyways here is how I see the scoring of the yellow totes alone in their respective situations (assuming they are compleatly contained by the auto zones):
___0___0___0____ = 6pts
.....0
___0________0___= 6pts
...0
...0
__0________= 20pts (possibly 26, depending is a stack and a set can
simultaneously exist)
Unread 03-01-2015, 12:50
AKA: Alex Tannahill
A similar situation is called out at the bottom of page 19. They are not in a single column and do not meet point A of being a stack.
Unread 03-01-2015, 12:59
AKA: Abby Wilson
......0
Okay, so that is considered a TOTE SET, which is defined by 3 golden totes in the auton area.
The CONTAINER SET is the tall recycling bins, NOT the totes. 3 of the large bins in the scoring area count for 8 points.
A STACKED TOTE SET are all 3 golden totes stacked on top of each other as per figure 3-1 , or 3.1.2.1 in the rules.
It appears, though I may be wrong, that 2 totes or two bins dont count?
FIRST mentor 2010-?
Unread 03-01-2015, 13:06
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
Originally Posted by rtfgnow View Post
I agree with your max, but you only get points for sets, so you need all yellow totes in the auto zone to get 6 points, you cannot get 4 points for only having two of them. The recycling containers only needs one to have a set.
I was inferring that all the yellow totes available at the start of the match need to be fully constrained by the auto zone in order to be considered a set.
A container set on the other hand does need to have three present in the auto zone in order to be counted (definition of container set, rule 3.1.2.1)
Unread 03-01-2015, 13:09
AKA: Alex Tannahill
The rule you quoted is right, but if you look closely they use the word any, not all when defining the container set.
Unread 03-01-2015, 13:16
normaldude8825 normaldude8825 is offline
FRC #1872
normaldude8825 is an unknown quantity at this point
I wish to confirm I am interpreting the following rule correctly:
LITTER Scored in/on RECYCLING CONTAINER 6 per RECYCLING CONTAINER
I am understanding that we are allowed to have various Recycling Containers one next to another and have one piece of Litter lying on top of these Recycling Containers instead of inserting one Litter per Recycling Container.
Unread 03-01-2015, 13:21
BenBraun3090 BenBraun3090 is offline
FRC #3090
BenBraun3090 is an unknown quantity at this point
___0___0___0____ =?
.....0
___0________0___=?
...0
...0
__0________=?
I will assume that all the totes are completely within the scoring zone.
Situation 1 would be worth 6 points, a Tote Set.
Situation 2 would be worth 6 points as well, still a Tote set because you need all 3 totes to be stacked to be a Stacked Tote set and worth 20 points.
Situation 3 would be worth 20 points, as it is a Stacked Tote set. This requires all of the totes to be stacked in a single stack.
See section 3.1.2.1
Unread 03-01-2015, 13:22
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
That is correct, the points are awarded on a per set basis, not per tote.
AKA: Alex Tannahill
You may score the litter on, not in the recycling container. The weight of the litter must be supported by a scored container.
Unread 03-01-2015, 13:26
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
The way I interpret it: there are a total of 10 recycling containers on the field: 3 in each alliance zone, 4 on the STEP. If any of those 3 are completely contained by the team's auto zone a container set is awarded.
