| Thread Tools |
Rating:
Display Modes |
#16
Re: 2015 Recycle Rush Scoring
I couldn't find anything in the rules (haven't read entire thing tho), can we open the totes and stack them inside of each other?
#17
G16 Blue Box, Item C.
#18
Please read page 19 of the manual. |
#19
They are intended to be closed- THey are zip tied shut. |
#20
I originally thought the coopertition points were a red herring since they won't really affect ranking since averages are calculated to 2 decimal places but the high value of the stacked totes probably means each alliance should try to put two yellow totes on the step once it is clear of grey ones. Assumes another robot will complete the stack of 4.
#21
You're forgetting a situation:
......0 ___0 0________ = ? (I believe this is a void configuration resulting in 6pts, however there was not an example given to this situation in the manual.) anyways here is how I see the scoring of the yellow totes alone in their respective situations (assuming they are compleatly contained by the auto zones): ___0___0___0____ = 6pts .....0 ___0________0___= 6pts ...0 ...0 __0________= 20pts (possibly 26, depending is a stack and a set can simultaneously exist) |
#22
A similar situation is called out at the bottom of page 19. They are not in a single column and do not meet point A of being a stack.
#23
Okay, so that is considered a TOTE SET, which is defined by 3 golden totes in the auton area. The CONTAINER SET is the tall recycling bins, NOT the totes. 3 of the large bins in the scoring area count for 8 points. A STACKED TOTE SET are all 3 golden totes stacked on top of each other as per figure 3-1 , or 3.1.2.1 in the rules. It appears, though I may be wrong, that 2 totes or two bins dont count? |
#24
A container set on the other hand does need to have three present in the auto zone in order to be counted (definition of container set, rule 3.1.2.1) |
#25
The rule you quoted is right, but if you look closely they use the word any, not all when defining the container set.
#26
I wish to confirm I am interpreting the following rule correctly:
LITTER Scored in/on RECYCLING CONTAINER 6 per RECYCLING CONTAINER I am understanding that we are allowed to have various Recycling Containers one next to another and have one piece of Litter lying on top of these Recycling Containers instead of inserting one Litter per Recycling Container. |
#27
Situation 1 would be worth 6 points, a Tote Set. Situation 2 would be worth 6 points as well, still a Tote set because you need all 3 totes to be stacked to be a Stacked Tote set and worth 20 points. Situation 3 would be worth 20 points, as it is a Stacked Tote set. This requires all of the totes to be stacked in a single stack. See section 3.1.2.1 |
#28
That is correct, the points are awarded on a per set basis, not per tote.
#29
The way I interpret it: there are a total of 10 recycling containers on the field: 3 in each alliance zone, 4 on the STEP. If any of those 3 are completely contained by the team's auto zone a container set is awarded.
