Go to Post You see the learning experience doesn't stop during construction. It goes on to competition or to everyone who looks at a picture on delphi, who studies the bot and says I like how they did this or I woulda changed this a bit. - Dan Richardson [more]
Unread 03-01-2015, 13:34
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
Re: Compatition Ranking
Originally Posted by GaryVoshol View Post
Why use the average? Why not just the total accumulated points? Every team is scheduled for the same number of matches, so why do we do the (extra) math?
I think it is to normalize the "perfect storm" random chance alliances, where 3 super powerful robots are paired by the all mighty randomized partner algorithm. It dilutes that one magic match where the stars align and the score ends up 3 times higher than your other matches, mainly because of a particular mix of robots and not so much the individual robot's performance. The average gives an adjusted and IMO more accurate portrayal of actual robot contribution over multiple matches, rather than cumulative score, where one magic match can boost a team's ranking beyond their typical performance.
Unread 03-01-2015, 13:42
Anteprefix's Avatar
Anteprefix Anteprefix is offline
FRC #1678 (Citrus Circuits)
Anteprefix is on a distinguished road
In what way does the average adjust the robot's contribution? The QA is just the cumulative score divided by a factor.
The scouting! It never ends!
Unread 03-01-2015, 13:52
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
Consider this scenario:
Last match of qualifications:
Team A: Average Score:98pts/match
Team B: 100pts/match
Team C: 102pts/match
Team D: 98pts/match
Team E: 100pts/match
Team F: 102pts/match
Seems like a fair match-up right? but the stars align for team A-B-C and...
Final score:A-B-C 300 | D-E-F 100
Even tough these teams were identical in their stats team A-B-C pulled out a significant win. The average scores of team D-E-F stay approximately the same, and while the teams were tied in the standings before this match took place teams A,B, and C are now all ahead of teams D,E, and F.
My point being: since the same number of qualification matches are played (excluding surrogates) why does averaging matter?
Unread 03-01-2015, 14:36
Kpchem Kpchem is offline
FTA, CSA, and all things technical
AKA: Kevin Emery
Kpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to behold
Under this system of averaging, it is easier to compare between events that run different numbers of matches. This could be especially valuable if events within a single district region have to run different numbers of matches.
That's my guess anyway.
FRC 360: 2008-2011
Full-time Volunteer: 2012 - forever
Unread 03-01-2015, 15:07
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
My updated insight is as follows- the averaging simply allows for an easier way to compare teams that have different number of matches played. For example:
Team A has a QA of 100pts/match and 4 games played
Team B has a QA of 110pts/match and 3 games played
This is a lot easier to compare than
Team A has 400 points total, and 4 games played
Team B has 330 points total, and 3 games played
Unread 05-01-2015, 12:17
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
I hope that District events stay with the standard 12 matches for all teams. This guarantees no surrogates and for smaller events also keeps a feasible inter-match minimum.
no stranger to the working end of a pencil
Unread 05-01-2015, 09:17
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
I Initially thought it was just to make the ranking nicer to watch, but it appears this doesn't happen...
Section 5.3.3:
Originally Posted by Ye Olde Maual
The total number of MATCH Points earned by a Team throughout their Qualification MATCHES, divided by their number of assigned MATCHES (excluding any SURROGATE MATCHES), then truncated to two decimal places, is their Qualification Average (QA).
The key word is assigned. It does not say matches played at that point.
This leads me to believe that the divisor of the average is constant through the whole event, actually making the whole averaging thing pointless for viewing purposes or... anything... over just a total. This seems really weird though, I'm guessing they don't mean that since, well, it doesn't make any sense.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 05-01-2015, 12:14
MikeE's Avatar
no team (Volunteer)
Section 5.3.3:
I don't have any special knowledge but I expect the Pit Display will show average score throughout the competition. From a tournament perspective Qualification Average doesn't have any role before final ranking, although in practice we all want to know where we stand throughout the competition.
