Go to Post Failure is not an option. - [more]
Unread 03-01-2015, 11:55
cbf cbf is offline
FRC #2877
cbf is just really nicecbf is just really nicecbf is just really nicecbf is just really nicecbf is just really nice
FRC 2015 Update Suite won't install on 64-bit Windows?
After downloading and unzip'ing the FRC 2015 Update Suite (https://decibel.ni.com/content/docs/DOC-34731), when I double-click on setup.exe on a 64-bit Windows 7 system I get an error:
"The version of this file is not compatible with the version of Windows you're running. Check your computer's system information to see whether you need an x86 (32-bit) or x64 (64-bit) version of the program, and then contact the software publisher."
Hard to believe that the release won't work on 64-bit systems. Was this just a bad stub setup.exe done at the last minute (it's only 1Kb!)?
Unread 03-01-2015, 15:24
cbf cbf is offline
FRC #2877
Re: FRC 2015 Update Suite won't install on 64-bit Windows?
Never mind.
My first attempt to unzip it had the wrong password, which left some improperly decrypted files around (including setup.exe), which were not overwritten when I correctly unzip'd it the second time. Blame 7zip.
Unread 03-01-2015, 15:31
riftware riftware is offline
Parent Mentor
AKA: Andrew Chandler
FRC #0031
riftware is an unknown quantity at this point
where was the password located? i'm still trying to find that in my kit.
Unread 03-01-2015, 15:35
cbf cbf is offline
FRC #2877
Not sure where it was in the kit, but others have already posted it:
R3C3CL3RU$H2015
