Go to Post Using my Little Orphan Annie Secret Decoder Ring, I have determined that the game hint reads: "Be sure to drink your Ovaltine" - Jill_ls101 [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 03-01-2015, 16:37
Jalerre's Avatar
Jalerre Jalerre is offline
FRC #4965 (FIRE)
Jalerre is on a distinguished road
Re: 2015: Year of the Mecanum
For those talking about driving over the bumps, I do believe that is prohibited. Don't quote me on this but I think it says so somewhere in the manual. Their primary only purpose is as a scoring platform so you don't need to worry about how mecanums are going to get over the bumps.
In regards to programming mecanums, I can say from experience that it is really easy. Our team has used them for the past 3 years. Both Java and C++ (I can't speak for Labview) have methods for programming a mecanum drive (2 methods in fact, at least in the 2014 library). Just plug in your parameters and that's all there is to it.
Finally, though I didn't agree with my team in the past about a mecanum drive train, this year I can really see the advantages. Because there won't be too much robot-to-robot interaction you won't have to worry about pushing power or traction. Also strafing will be really useful when you need to line up to stack the totes and recycling bins.
Unread 03-01-2015, 16:56
nicholsjj's Avatar
nicholsjj nicholsjj is offline
AKA: John Nichols
no team (Devil Bots)
nicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant future
The code in labview is a canned VI. The only problem that I have had to help teams with is many younger teams make the rotation the throttle axis. Most of the time I have them switch to a button switch statement for turning and it works out fine, some still like other axis turning methods and it can be worked through with the Get axis. Our team has decided to use Mecanum since the no defense is in play and we might try to go for the stack in auto. Mecanum will work out nicely for strafing left or right and picking up as long as you use a gyro for drift. The only initial issues we are concerned with is the frame spacing for the totes and going over the scoring platforms. We think 8" HD's will be fine enough to prototype though.
2011-FRC Team 3862, Team Captain
2012-FRC Team 3862, Strategy Mentor
2013-FRC Team 3885, Programming Mentor, Razorback Regional, Curie Inspector
2014- FRC Team 3885, Programming Mentor, Arkansas Regional, Newton inspector
2015-??? Teacher Murphysboro High School
“They call it coaching but it is teaching. You do not just tell them…you show them the reasons.”- V. Lombardi
Unread 03-01-2015, 17:08
The game reveal video at 1:13 shows a bot driving over the platform.
Unread 03-01-2015, 18:01
jtrv's Avatar
jtrv jtrv is offline
github.com/jhtervay
AKA: Justin
FRC #2791 (Shaker Robotics)
jtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to all
He might have been talking about the middle platform, but yes, the scoring platforms can be crossed.
Unread 03-01-2015, 19:26
In the given context, that wouldn't make sense.
Also note that the middle is called a step, not a platform.
Unread 03-01-2015, 22:06
Jalerre's Avatar
FRC #4965 (FIRE)
I didn't see it in the manual anywhere that's just the conclusion that our team had come to. (I didn't try to confirm it I just trusted them)
Unread 03-01-2015, 22:09
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
If you have 3 rollers on the carpet and one on the hdpe, does the coefficient of friction come into play? I assume as long as you don't break traction on any of the wheels you can effectively transmit force vectors to the ground?
Unread 03-01-2015, 19:33
theCADguy's Avatar
theCADguy theCADguy is offline
Design Team Student Leader
AKA: Sean Gibbons
FRC #0020 (The Rocketeers)
Team Role: CAD
theCADguy has a spectacular aura abouttheCADguy has a spectacular aura about
I believe that you are thinking of the step in the middle. You can traverse the scoring zones, however.
Also, quick question:
Can a mechanum drive be set up where the length of the drive train is greater than the width, or does it require a square wheel configuration?
Unread 03-01-2015, 19:36
StephenNutt StephenNutt is offline
FRC #0172 (Falgor)
StephenNutt is an unknown quantity at this point
Can a mechanum drive be set up where the length of the drive train is greater than the width, or does it require a square configuration?
You can set it up with any aspect ratio, square, long or short (within reason)
Unread 03-01-2015, 19:56
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
However, the farther you get from a square configuration, the more scrub you'll get when turning in place. Also, not square configs mean the wrong mecanum layout will make your robot turn backwards. Heh.
Unread 03-01-2015, 20:25
For a mec, the inverse kinematics are the same1 as long as it's rectangular.
1ignoring roller friction, axial free play, and carpet compliance
Unread 06-01-2015, 11:56
Pollux Pollux is offline
FRC #1816
Pollux is an unknown quantity at this point
There's nothing in the manual about not driving over the scoring platforms. In fact, it makes sense that many robots would have to drive on them in order to deposit their payloads.
