| Thread Tools |
Rating:
Display Modes |
Potential Omni Drive System
Hey guys. Someone had an idea for a drive train on our team that seems a little funky but I can't put my finger on why. What do you guys think are the advantages and disadvantages of this drivetrain:
Two Large wheels in the back and two perpendicular omni wheels in the front for a type of swerve drive. -- -- | | Kind of like that. |
Re: Potential Omni Drive System
Are the back wheels swerve?
It seems like it probably drive like a shopping cart? I feel that would be the case. Of course I'm just guessing, but I feel like the front of your robot would float a lot. It would be very hard to drive straight unless everything on your back wheels run perfect (proper weight distribution, power distribution, etc.) Might be too finicky for its advantages. Just my 2 cents though |
Thanks T3_1565. I hadn't thought of that.
At Ether, I thought that it's a weak system that can at least swerve; why do you think it can't swerve. |
It can't rotate while driving in a straight line like a swerve can. It can't pivot around any arbitrary point like a swerve can. |
#8
If the omni wheels are moving orthogonal to the two wheels in the back, won't it be able to rotate while driving and pivot an arbitrary point? Thanks. |
#9
Rotating the robot while driving requires rotating the back wheels. Rotating the back wheels changes the robot's direction of travel.
#10
Of course it can turn while driving, but so can a drop-center 6WD skid steer. Quote:
#11
Switching to a drive configuration that looks something like:
| - - | (all four wheels are omniwheels) |
#12
Inverse kinematics:
S1 = STR + (L/2)*Omega S2 = FWD + (W/2)*Omega S3 = STR - (L/2)*Omega S4 = FWD - (W/2)*Omega ... then normalize if any wheel exceeds max speed W = trackwidth, ft FWD = forward, fps STR = strafe right, fps Omega = clockwise rotation rate around center, rad/sec S1 front right wheel linear speed, fps S2 front left wheel linear speed, fps S3 rear left wheel linear speed, fps S4 rear right wheel linear speed, fps Last edited by Ether : 04-01-2015 at 11:26. Reason: changed to engineering units for more general applicability |
#13
Ether, since this a relatively novel drive that lacks the wealth of information available for other drives, do you think you could list some disadvantages of a drive like this (especially compared to comparable drive trains like slide, mecanum and skid-steer)? I'm specifically interested also in the speed and rotational limitations/capabilities of a drive like this. Also ability to drive straight and the effect of CoMon driving. Based on CMP footage, it looks like the they used some sort of more standard 4WD in 2010. May have been a different year or a pre-CMP design. Last edited by Spoam : 04-01-2015 at 10:57. |
#14
I've never built, driven, or even seen a drive like this in action, so take the following speculations with a grain of salt. Disadvantages It's not going to be as easy to drive in a straight line as skidsteer or swerve. Advantages It has (theoretically) all the degrees of freedom that a mec or swerve has. (Slide drive does not). Quote:
Whoops, that should say CoM as in center of mass. Ie, theoretically, would weight distribution affect this robot's ability to turn or drive properly?
