Go to Post FIRST is really a community, we only compete on the field. - InFlight [more]
Unread 03-01-2015, 13:54
ktcottrell ktcottrell is offline
FRC #0687
ktcottrell is an unknown quantity at this point
scoring levels
My team is looking at the scoring levels and the game manual shows only 6 scoring levels. Does anyone know if there are more scoring levels such as a level 7 or 8? Or is level 6 the highest and get more points for having totes and cans above level 6?
Unread 03-01-2015, 13:56
BenBraun3090 BenBraun3090 is offline
FRC #3090
BenBraun3090 is an unknown quantity at this point
Re: scoring levels
The rules state that totes cannot be stacked above 6ft 6in. so there are only 6 scoring levels
Unread 03-01-2015, 14:10
Dominick Ferone's Avatar
Dominick Ferone Dominick Ferone is offline
FRC #5030 (The Second Mouse)
Dominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really nice
Re: scoring levels
It just said the robot couldn't be taller then 6 ft 6 inches, doesn't say the crates can't go higher.
2010-2013 Team 353 The POBots - Student, 2014-present Alumni.
2014- present Team 5030 The Second Mouse - Mentor and Founder.
Unread 03-01-2015, 14:11
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: scoring levels
On the top of page 21, it states the totes will not be scored if it is above the top of the backstop (height of 6'6"). Nothing stops you from putting more totes on it though.
Unread 03-01-2015, 14:12
Metis Metis is offline
FRC #4203
Metis is an unknown quantity at this point
Re: scoring levels
A Gray TOTE is scored if it is fully supported by a SCORING PLATFORM and no portion of the TOTE extends above the top of the
BACKSTOP.
So the height of the backstop constrains the height of the stack. The backstop is also 6'6'' tall.
Unread 03-01-2015, 14:22
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
Re: scoring levels
According to rule (2.3.1) the totes are 12.1 inches tall. This limits the total number of totes that will be scored per stack to six.
Since Recycling containers are scored from their lowest point this means that the containers can be above the 6'6" backstop, and still scored, so long as part of the container falls within the height of the backstop. Am I correct in this interpretation?
Unread 03-01-2015, 14:24
Re: scoring levels
Originally Posted by Skyehawk View Post
According to the rules (2.3.1) the totes are 12.1 inches tall. this limits the total number of totes that will be scored per stack to six.
Since Recycling containers are scored from their lowest point this means that the containers can be above the 6'6" backstop. Am I correct in this interpretation?
Yes. At least as far as I can tell.
Unread 03-01-2015, 14:25
AKA: Alex Tannahill
Re: scoring levels
I would suggest reading page 21.
A RECYCLING CONTAINER is scored if it is fully supported by only scored Gray TOTES. Points for a scored RECYCLING
CONTAINER are awarded based on the lowest LEVEL in which any portion of the RECYCLING CONTAINER resides. In Figure 3-4,
colors have been added to indicate the LEVELS on the BACKSTOP. In both examples (A and B), the lowest part of the RECYCLING
CONTAINER is in LEVEL 3.
There is nothing restricting the height of the recycling container.
Unread 03-01-2015, 15:23
GaryVoshol's Avatar
Cogito ergo arbitro
Re: scoring levels
But if the lowest point of the CONTAINER is not in a scoring level (because it's above the level) then it wouldn't be worth anything to put it up there.
And if you dump it over the side, you're going to get penalized.
(since 2004)
Unread 03-01-2015, 15:35
AKA: Alex Tannahill
Re: scoring levels
Figure 3-4 has an arrow above level 6. I took this to mean that level 6 extended as high as possible.
Unread 03-01-2015, 17:16
p00rleno p00rleno is offline
Team Advisor & Former Team Leader
AKA: Andy
FRC #2590 (Nemesis)
p00rleno is on a distinguished road
Re: scoring levels
Crossposting this from the other thread, because hey it's relevant, I threw together a diagram
Unread 04-01-2015, 16:05
dusundavar's Avatar
dusundavar dusundavar is offline
MechHead
FRC #2673 (Tenacious Technicians)
dusundavar is an unknown quantity at this point
Re: scoring levels
Because the robot can at no point in the match exceed 78'' (6'6), scoring mechanisms must be carefully designed in order to avoid a penalty.
