Go to Post Some said the aluminum foil gave the robot a NASA-like quality, but others pointed out that blanketing components with a highly-conductive material that blocked air flow was probably not going to help get us to Einstein. - beerobber [more]
Unread 03-01-2015, 17:48
Herbie_3633 Herbie_3633 is offline
FRC #3633
Herbie_3633 is infamous around these partsHerbie_3633 is infamous around these parts
Error installing FRC Eclipse Plugin.
When I try to install the FRC Plugin to our laptop using these instructions https://wpilib.screenstepslive.com/s...eclipse-c-java . I have tried both on and offline installs with the same error.
The error message that I get when trying to install:
Cannot complete the install because one or more required items could not be found.
  Software being installed: Robot C++ Development 0.1.0.201501020322 (edu.wpi.first.wpilib.plugins.cpp.feature.feature.group 0.1.0.201501020322)
  Missing requirement: edu.wpi.first.wpilib.plugins.core 0.1.0.201501020322 (edu.wpi.first.wpilib.plugins.core 0.1.0.201501020322) requires 'bundle org.eclipse.ant.launching 1.0.200' but it could not be found
  Cannot satisfy dependency:
    From: WPILib Robot Development Core 0.1.0.201501020322 (edu.wpi.first.wpilib.plugins.core.feature.feature.group 0.1.0.201501020322)
    To: edu.wpi.first.wpilib.plugins.core [0.1.0.201501020322]
    From: Robot C++ Development 0.1.0.201501020322 (edu.wpi.first.wpilib.plugins.cpp.feature.feature.group 0.1.0.201501020322)
    To: edu.wpi.first.wpilib.plugins.core.feature.feature.group [0.1.0.201501020322]
Unread 03-01-2015, 18:54
bh202548 bh202548 is offline
FRC #1701
bh202548 is an unknown quantity at this point
Re: Error installing FRC Eclipse Plugin.
Could you please specify the operating system of the laptop and also if you are trying to develop with C++ or Java?
Unread 03-01-2015, 18:57
FRC #3633
The laptop is windows 7 64 bit. I am trying to install C++.
Unread 03-01-2015, 18:59
FRC #1701
Thank you. I am going to try and replicate the error and then see if I can fix it. Hopefully I can help you.
Unread 03-01-2015, 19:42
FRC #1701
I am sorry but I can not seem to replicate the error. My best advice to you is double check you have the 64 bit jdk and jre installed, make sure you installed roborio c++ toolchain, and also you have eclipse for c++ 64 bit. Sorry I could not be more helpful. Try double checking those things and reinstall them and tell me if any of it works.
Unread 03-01-2015, 20:13
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
try making sure eclipse is up to date, and you have the proper implementation of java. I know in the beta test it was required to have 32 bit java sdk installed.
EDIT: Typo
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 03-01-2015, 21:38
Jeanne Boyarsky Jeanne Boyarsky is offline
Java Mentor
FRC #0694 (StuyPulse)
Jeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud of
In addition to the 32 bit suggestion, make sure you downloaded the right version of Eclipse; It should be:
Select the C/C++ version of eclipse. The C/C++ version should be selected regardless of programming language choice (C++ or Java). You can also select one of the other versions, but that will require adding the C Development Tools (CDT). You should choose the version of eclipse that matches your operating system and version of Java from above.
Team 694 mentor 2010-present, FIRST Volunteer and Co-organizer of FIRST World Maker Faire Tent
2012 NYC Woodie Flowers Finalist
2015 NYC Volunteer of the Year
