Go to Post One last thing, if a mechanical part fails on you, sometimes you can get a little bit of noise back into it by yelling at it, kicking it, or pounding on it with your fist. This might put enough back into it so it will work for a few more minutes. - KenWittlief [more]
Unread 03-01-2015, 19:40
wbrehob wbrehob is offline
FRC #2832
wbrehob is an unknown quantity at this point
Question Scoring Platforms
Does anyone know of a source from which we could purchase the white scoring platforms? Even if it's just the HDPE sections which we can attach to plywood, something to start with would help. Thanks for any suggestions.
Unread 03-01-2015, 19:44
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
amesmich is an unknown quantity at this point
Re: Scoring Platforms
Pretty common stuff heres one place Mcmaster.
http://www.mcmaster.com/#standard-pl...sheets/=vb8gm3
Unread 03-01-2015, 19:51
BenDSterling's Avatar
BenDSterling BenDSterling is offline
Alumni, Mentor, Volunteer
FRC #6325 (Reset Robotics)
BenDSterling will become famous soon enough
Normally andymark will see the complete field components soon after kickoff.
If you would like to build it yourself here are the instructions: https://www.dropbox.com/s/3v8gsh4dxj...Field.pdf?dl=0
You can get the HDPE here: http://www.usplastic.com/catalog/item.aspx?itemid=23869
Lead Mentor: FRC Team Reset Robotics (#6325)
Mentor: FTC Teams #9686 & #10396
Head of AV for Georgia FIRST Robotics
FTC South Super Regional planning committee member
Unread 03-01-2015, 21:02
DonRotolo's Avatar
Back to humble
FRC #0832
Don't use the dropbox file; instead go to www.usfirst.org for the official file. Frank's blog asked teams to not host FRC files, whomever put that file on Dropbox surely had not read that blog post...
