Go to Post I believe that your career should support your dreams. - Tytus Gerrish [more]
Unread 03-01-2015, 20:12
lark95's Avatar
lark95 lark95 is offline
Red Ranger
AKA: Joe L.
FRC #3418 (RoboRiot)
Team Role: Driver
lark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of light
Which controler for driving mecanum?
Just wondering wich gamepad or joystick other teams are using drive mecnum. Also what are the control layouts that teams use.
Unread 03-01-2015, 20:15
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: Which controler for driving mecnum?
In the past, 857 has used a three-axis joystick for mecanum drive.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 03-01-2015, 20:17
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
Last year 461 used 2 joysticks. One joystick was just the translation and the other was rotation.
461 Westside Boiler Invasion
45 Technokats
Unread 04-01-2015, 09:25
rjmah rjmah is offline
rjmah will become famous soon enough
Re: Which controller for driving mecanum?
1246 used to do custom programming on a single joystick. Normal 4 wheel drive for front and back quadrants (up to 45 degrees on the joystick). Full left and full right would be 100% strafe steering. In between, a blend for strafe steering.
Robert Mah
Team 1246 Agincourt Lancers
Unread 04-01-2015, 09:40
Kingland093 Kingland093 is offline
FRC #4215 (Trinity Tritons)
Kingland093 will become famous soon enough
4215 has experimented with 2 driving styles. Both use 2 2-axis joysticks. The first has one joystick for arcade driving and one just for strafing. The other is a tank drive with one of the sticks being able to strafe.
McGill University Mechanical Engineering Class of 2020
FRC 4215: Trinity Tritons 2013-2016 (Programmer, Strategy, Driver)
2015 MRI Winner (with 3130, 2052, and 2531)
2015 MN State Championship Winner (with 2512 & 3130)
2015 Double DECC'er Winner (with 3130 & 525)
2015 Northern Lights Winner (with 3130 & 525)
Unread 04-01-2015, 09:52
thinker&planner thinker&planner is offline
AKA: CAAAAAD
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
Being the driver, and liking tank style, I requested that we control (not drive) our robot with tank-style controls. We used an Xbox controller and had the left-y control the left side forward/backwards and the right-y for the right side. The strafing was controlled by the triggers, which were analog on the controller that we used. If we do it again, I would use two joysticks in a tank formation and modify the triggers to be analog (or use the x-axis of one of them for strafing).
The trick was averaging in the strafing at the same time, which our amazing programmer had a true "Eureka!" moment when she figured it out. Her method provides a more "natural" way (if you naturally like tank-style controls) for mecanum the full mobility of mecanum still retained.
I'll try to find the algorithm and put it here soon.
Unread 04-01-2015, 10:32
I meant to say arcade until the stick gets to 45 degrees. I'm pretty sure our programmer just used a linear proportion to give the driver strafe "steering". As you know, sideways steering is pretty inexact anyway.
Robert Mah
Unread 04-01-2015, 12:05
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
Last year we used an Xbox controller and controlled it call of duty style. I liked that setup a lot and want to do it again, but my team this year wants tobdo a 3 axis joystick because it has more resolution
Unread 04-01-2015, 13:19
Here's a common way to do it:
Forward = (Yleft + Yright) / 2
RotateCW = (Yleft - Yright) / 2
Then feed the Forward and RotateCW values into the Y and Rotation inputs, respectively, to the MecanumDrive_Cartesian method1 in WPILib (or LabVIEW). Use a joystick X axis or something else for the X (strafe) input.
1void RobotDrive::MecanumDrive_Cartesian(float x, float y, float rotation, float gyroAngle)
Unread 05-01-2015, 14:02
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
The way our team hypotheses to drive it was to use an x-box controller with the left stick be the forward back left and right and the triggers to rotate left and right.
Unread 03-01-2015, 20:25
alopex_rex's Avatar
alopex_rex alopex_rex is offline
Rainbow Professionalism Dash
AKA: Scott Morton
FRC #0830 (The RatPack)
alopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond repute
We did mecanum drive on an off-season project once. We used a Logitech Dual Action controller (an older version of the F310, and basically equivalent to it).
The control scheme we used was:
Left stick y-axis: speed forward/backward
Left stick x-axis: strafe left/right
Right stick x-axis: rotate left/right
In other words, we used RobotDrive::MecanumDrive_Cartesian (in WPILib), with LeftY, LeftX and RightX for the x, y and rotation arguments. So it's the simplest/laziest control scheme, but it seemed to work well, and it's intuitive for the driver.
I'm curious to see what controls teams with more mecanum experience prefer.
Unread 03-01-2015, 20:36
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
We used a three axis Logitech joystick to control our field oriented mecanum drive last year. I liked having it on one stick, but we had to put a deadband on the rotation axis to keep it from turning too much by accident.
Unread 03-01-2015, 20:41
lark95's Avatar
Red Ranger
AKA: Joe L.
Team Role: Driver
this is what we have used in the past.
But this year i would like to atleast try the gamepad with left stick for strafing and right stick for rotation
Unread 03-01-2015, 20:54
Metis Metis is offline
FRC #4203
Metis is an unknown quantity at this point
We had a good experience using an Xbox controller. Strafing was the left joystick, rotation the x-axis of the right joystick, and we ignored the final axis.
Unread 06-01-2015, 01:32
Mecanum Wheel's Avatar
Mecanum Wheel Mecanum Wheel is offline
It's spelled mecanum
AKA: Bengt Ilon
Mecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond repute
mecanum*
