Go to Post Time to iterate, more. - jwfoss [more]
View Poll Results: Mecanum or Slide?
Mecanum 77 38.69%
Slide 73 36.68%
Other 49 24.62%
Voters: 199. You may not vote on this poll
Unread 03-01-2015, 20:17
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
Re: 2015: Mecanum or Slide?
Originally Posted by Mineboy2300 View Post
I would go with slide because it provides maneuverability and speed but doesn't have the problems with balance that mecanum does. it would take a lot of engineering to make sure that the entire robot is balanced both with and without the totes on it.
The key to a proper mecanum isn't a perfectly balanced robot, it's a suspension system. have each wheel be able to bounce up and down and you're set. Once you've finished that, programming is almost simply than skid steer code.
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 03-01-2015, 20:29
String String is offline
String will become famous soon enoughString will become famous soon enough
Slide. Since pushing power isn't very important this year slide allows teams to only use 3 motors and gain holonomic motion. It's simpler to understand and program as well, and it can be designed lighter than a mecanum drive since it only requires 3 gearboxes.
Unread 03-01-2015, 20:32
Originally Posted by Sparkyshires View Post
The key to a proper mecanum isn't a perfectly balanced robot, it's a suspension system. have each wheel be able to bounce up and down and you're set..
Not quite. You actually need a keyring full of keys.
http://www.chiefdelphi.com/forums/sh...3&postcount=41
Unread 03-01-2015, 20:36
DJ Carpenter's Avatar
DJ Carpenter DJ Carpenter is offline
Challenge Accepted
FRC #1741 (Red Alert)
DJ Carpenter is an unknown quantity at this point
Our team is doing the final design matrix to choose this tomorrow. I personally favor slide, as it has all of the advantages of mecanum with the speed of tank drive. Only problem is weight...
Unread 03-01-2015, 20:41
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
Do you mean weight in comparison to mecanum or in general? I'm trying to see what why a slide drive would be so heavy.
Mecanum
4 wheels
4 gearboxes
Slide
~5 wheels
~3 gearboxes
Does a wheel weigh similarly as a motor and gearbox?
461 Westside Boiler Invasion
45 Technokats
Unread 03-01-2015, 20:45
Did you mean "all" literally?
Unread 03-01-2015, 20:50
Mike Marandola Mike Marandola is online now
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Mecanum
4 wheels
4 gearboxes
Slide
~5 wheels
~3 gearboxes
Keep in mind the weight difference between a mecanum and omni wheel.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 03-01-2015, 20:52
Originally Posted by Mike Marandola View Post
Key in mind the substantial weight difference between a mecanum and omni wheel.
http://www.chiefdelphi.com/forums/sh...39#post1420039
Unread 03-01-2015, 20:54
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
Originally Posted by Cash4587 View Post
Tank drive.
amen
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
Unread 03-01-2015, 21:01
who716's Avatar
drop center allows for turning on the center of the robot for quick maneuverability i like that option
Unread 03-01-2015, 21:21
mannybjh's Avatar
mannybjh mannybjh is offline
AKA: Ben Hogan
FRC #0020 (Team 20)
mannybjh is an unknown quantity at this point
Originally Posted by theCADguy View Post
Personally, I would prefer a slide drive. It grants the most mobility at the least amount of complexity. It can be mechanically implemented similarly to a tank drive (save for the sideways mobility wheels), which is a style of drive train that Team 20 is accustomed to. Also, it still has more traction than mechanum, which may come in handy on the slick HDPE scoring zones.
Just my 2 cents
I second that
Unread 03-01-2015, 22:11
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Who said you have to use gearboxs for mecanum or H-drive? Save your weight and use a single reduction...unless you plan on playing defense on your own alliance. There are some nice new resources from vex that will make this super easy for some teams.
Just a tid bit: If your doing H-drive or "slide"....please don't solid mount your strafe wheel and expect it not to weaken or break when you hit the bumps.
-Ronnie
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 03-01-2015, 22:20
KineticCougar KineticCougar is offline
FRC #5250
KineticCougar is an unknown quantity at this point
How much do mecanum wheels cost and where can I get them? Are they COTS items?
Unread 03-01-2015, 22:22
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
AndyMark: http://www.andymark.com/Mecanum-s/53.htm
VexPro: http://www.vexrobotics.com/vexpro/mo...um-wheels.html
Both AndyMark and VexPro are VENDORS.
Unread 04-01-2015, 16:14
FRC #5250
Originally Posted by cgmv123 View Post
What are the size restrictions for the wheels? Can I put 4" wheels on my robot?
