Go to Post Remember: This is High School Competition. - rich2202 [more]
Unread 03-01-2015, 21:38
Jeanne Boyarsky Jeanne Boyarsky is offline
Java Mentor
FRC #0694 (StuyPulse)
Jeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud of
Re: Error installing FRC Eclipse Plugin.
In addition to the 32 bit suggestion, make sure you downloaded the right version of Eclipse; It should be:
Select the C/C++ version of eclipse. The C/C++ version should be selected regardless of programming language choice (C++ or Java). You can also select one of the other versions, but that will require adding the C Development Tools (CDT). You should choose the version of eclipse that matches your operating system and version of Java from above.
Team 694 mentor 2010-present, FIRST Volunteer and Co-organizer of FIRST World Maker Faire Tent
2012 NYC Woodie Flowers Finalist
2015 NYC Volunteer of the Year
