Go to Post Im ready for anything. - davidthefat [more]
Unread 03-01-2015, 21:51
lark95's Avatar
lark95 lark95 is offline
Red Ranger
AKA: Joe L.
FRC #3418 (RoboRiot)
Team Role: Driver
lark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of light
Long conveyer to move boxes
So i have a very weird question. What if you were to build a robot that was just a long conveyer from the box feeding station right to the nearest scoring zone? Even if it only stacked 2 totes high another robot could finish he stacks. Even given the two main concerns that I see, wight and the transportation perimeter, is this even a legal to do something like this?
Unread 03-01-2015, 21:53
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Long conveyer to move boxes
As long as you can build the robot to fit within transport configuration and under 120 lbs there are no limits on robot size (there is a vertical limit as Jacob said below and I forgot to mention) during the match. Be careful if you totally rely on other people will be able to increase stack size, though.
Unread 03-01-2015, 21:55
Jacob Bendicksen's Avatar
Jacob Bendicksen Jacob Bendicksen is offline
Figuring out what's next
Jacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond repute
Simon said it. As long as you're under 120lbs, under 78 inches, and fit inside the transport configuration, go for it. We'll have to be careful when brainstorming this year not to confine ourselves with past rules that no longer apply - this is the first time in a while that something like this has been theoretically legal.
jacobbendicksen.com | @jacobbendicksen
Yale University Class of 2020
Team 1540 | 2012-2016
7 Chairman's Awards, 6 other awards, 2015 Dean's List Finalist, 1 event win, 2 finalist finishes. Thanks for an amazing ride.
Unread 03-01-2015, 21:57
AKA: Simon Bohn
There is also an interesting opportunity to detach and play with two robots, as long as they are linked together (including power), or take up large swathes of the field sweeping things around. The robot rules are really interesting this year.
Unread 03-01-2015, 23:19
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Very nifty concept, like 469-ish nifty. Folding out two 6' conveyors out from a 3' conveyor to get 15' of conveyor - that'd go a pretty good ways across the closer white platform while staying out of the way of the other robots. Add any kind of height adjustment to it and it's a solid idea.
Unread 04-01-2015, 18:44
electronicsdude's Avatar
electronicsdude electronicsdude is offline
AKA: Spencer
FRC #4918 (The Roboctopi)
electronicsdude will become famous soon enoughelectronicsdude will become famous soon enough
My worry is that of the mobility of other robots with a robot that large on the field. The second some of the gray totes are disturbed the field could become a mess.
Unread 04-01-2015, 19:25
Harman341 Harman341 is offline
FRC #0341 (Miss Daisy)
Harman341 is a glorious beacon of lightHarman341 is a glorious beacon of lightHarman341 is a glorious beacon of lightHarman341 is a glorious beacon of lightHarman341 is a glorious beacon of lightHarman341 is a glorious beacon of light
It's perfectly legal. The problem is you would be great at transporting crates to one spot.
Unread 04-01-2015, 19:27
AndyBare AndyBare is offline
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Unless you support your conveyor system (built in sections) on mechs or something, and slide them around, kind of like a sidewinder.
Andy Bare
Team 1261
Unread 04-01-2015, 19:42
grainne grainne is offline
Lead Programmer
FRC #0811 (Team 811 Cardinals)
grainne is an unknown quantity at this point
i mean you could also make a giant wall going across and put it right up next to the drivers station in the beginning and just drive forward in auto and therefore push all the yellow totes and those containers into the auto zone.
Unread 04-01-2015, 20:08
AKA: Simon Bohn
I think there's a good argument to be made that 18 pts every time, if executed correctly, would be a very valuable autonomous to have.
Unread 05-01-2015, 19:17
seamushroom seamushroom is offline
AKA: Seamus
FRC #2491 (No Mythic)
Team Role: CAD
seamushroom is an unknown quantity at this point
Actually, is it?
in the rule book it says
"4.2 General ROBOT Design
R2
A Team must submit their ROBOT for Inspection. The ROBOT must be built by the FRC Team to perform specific tasks when competing in RECYCLE RUSH. The ROBOT must include all of the basic systems required to be an active participant in the game – power, communications, control, and movement. The ROBOT implementation must obviously follow a design approach intended to play RECYCLE RUSHSM (e.g. a box of unassembled parts placed on the FIELD, or a ROBOT designed to play a different game does not satisfy this definition)."
How do we define movement? moving parts o the robot or the ability to move the robot with wheels etc.?
Unread 05-01-2015, 19:36
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by seamushroom View Post
Actually, is it?
R2
I very much doubt any referee (or inspector) would say that this type of robot would not be an "active participant" in the game. I would also Q&A this specific rule to see if motion of the entire robot (not just appendages) is required.
___________________
- Tennyson, Ulysses
Unread 05-01-2015, 20:09
BethMo BethMo is offline
FRC #0948 (NRG (Newport Robotics Group))
BethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to behold
Some of the Ultimate Ascent robots had no wheels -- they started out under the pyramid and just climbed.
Unread 05-01-2015, 20:13
Canon reeves Canon reeves is offline
FRC #4490 (That One Team)
Team Role: Driver
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
This would be pretty cool, and you don't even need to have a conveyer, if you had a bar that folded once and pivoted at the frame you could just drive forward with everything? it would be consistent, and pretty easy.
Unread 18-01-2015, 23:47
mrnoble's Avatar
mrnoble mrnoble is online now
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
I'm looking forward to the crane robot. Im sure it will happen multiple times, and that some of them will succeed.
