Go to Post The gearbox can be anything, just as long as it weighs less than 0 lbs, and yes, I'm talking about negative weight here. - NoodleKnight [more]
Unread 03-01-2015, 23:14
2508electronics 2508electronics is offline
The One Man Electrical Team
FRC #2508 (Armada Robotics)
Team Role: Electrical
2508electronics is an unknown quantity at this point
VRM power for radio
I noticed that the connection on the VRM that is specifically labeled radio power is 12 volts. On the back of the radio, it says that the input voltage is 5 volts. Did I read something wrong or forget something (the 12V DC to 5V DC converter from past years?). I don't recall seeing the DC converter in the Kit of Parts or on the Kit of Parts list.
Unread 03-01-2015, 23:16
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: VRM power for radio
The D-Link should be connected to the 5V side of the VRM. It's possible the sticker on yours got placed on the wrong side.
Unread 03-01-2015, 23:17
The sticker is on the 5V connector on the one in the wiring document and on ours. Is yours different than the picture under Radio Power and Ethernet on this page?
Unread 03-01-2015, 23:19
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
The radio is 5V. Plug the D-link radio into one of the 5v 2A channels on the VRM.
Do no power any other 5V 2A devices from this VRM. Using the 12V is ok on the same VRM for other 12V devices.
If you require additional high amp 5V sources use a second VRM.
If you have any other quick questions check out http://controls.team2168.org, we have a lot of answers to most questions up there.
Hope this helps,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 03-01-2015, 23:24
I found my problem. I didn't realize that 5V was all on one side and not green was 5V and Gray was 12V. The radio power sticker was covering up the label.
Unread 04-01-2015, 00:16
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Kevin Selavko is on a distinguished road
Shorts on ANY of the 5 volt ports will cause the radio to reboot in my experience.
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
