Re: Tote Stack Maximum
Correct. The answer lies right in the first line of Tote Gameplay (3.2.1.3)
Interestingly enough I don't see BACKSTOP defined even though it is bolded. Regardless, it's clear to see from the figures below that description that a max of 6 TOTES would fulfill that criteria. I did a quick calc and it looks like you're clear by about 6 inches from the top of the BACKSTOP at 6 TOTES. Last edited by dellagd : 04-01-2015 at 01:40. |
The backstop is defined on page 8 of section 2 in the (current) manual. It's the 6'6" aluminum pipe that shows the 6 levels (white gaffers tape). This is also why the maximum is 6 totes.
Thanks! Somehow I missed that in my read-throughs.
Are they emphasizing tote in a way that says 'The bins can be above the top, not the tote?', or is it bold because it is a keyword?
Yes. In scoring, it is clear that the Container is assumed to be on top of 6 Totes. That requires the Container (and litter) to exceed the height of the backstop.
#7
I do got a question. I don't know if this is relevant. But according to rules, would it be allowable to have the recycling container (trash can) be on two separate stacks of grey totes that are side by side? I am mainly thinking of the case were a container is on it's side (not upright). The container would be more secure on two sets of stacked totes side by side rather than trying to balance it on one set of totes.
#9
