Go to Post Coming between me and my Hawaiian shirts would be like trying to get between Dean and denim. - dlavery [more]
Unread 04-01-2015, 02:24
Dentyne_Ice97 Dentyne_Ice97 is offline
FRC #3965
Dentyne_Ice97 is an unknown quantity at this point
ROBOT DIMENSIONS
"R3
B. the ROBOT must be able to be arranged into a TRANSPORT CONFIGURATION with dimensions which do not exceed 28
in. wide, 42 in. long, and 78 in. tall"
Does this mean that the robot can extend in any direction horizontally to be as wide or as long as we want after the start of the match? or are we solely limited to 28x42x78?
Unread 04-01-2015, 02:26
jaykris284 jaykris284 is offline
FRC #1261
jaykris284 is an unknown quantity at this point
Re: ROBOT DIMENSIONS
Originally Posted by Dentyne_Ice97 View Post
"R3
It can extend to be as long or wide as you want.
Jay Kris
Team 1261
Attending in 2015:
Palmetto Regional, Peachtree Regional
Unread 04-01-2015, 02:29
kitare102 kitare102 is offline
AKA: Eric
FRC #3042 (Cobalt Catalysts)
kitare102 is an unknown quantity at this point
Don't quote me on this, but it seems that the transport rule is pretty much the same as the expansion rule from last year, except your robot doesn't need to expand automatically once the game starts. It can start the game already in its expanded configuration, it just needs to be able to get back into transport mode once you take it off the field.
Unread 04-01-2015, 03:13
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
That is correct. The Transport Configuration only applies when the robot is being moved from the pit to another location like the field.
TRANSPORT CONFIGURATION – a configuration of a ROBOT which does not exceed 2 ft. 4 in. wide x 3 ft. 6 in. deep x 6 ft. 6 in. tall and is
used in transferring ROBOTS among competition locations (e.g. the Team’s Pit, the Practice Field, Inspection, the ARENA, etc.)
The only size restriction rule that applies during the match is the height restriction. Your robot can grow beyond the transport configuration limits, and it seems that doing so manually once the robot is on the field will be permissible.
R3 The ROBOT must satisfy the following size constraints:
A. during a MATCH, the ROBOT height may not exceed 78 in.
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 04-01-2015, 03:22
wesleyac's Avatar
wesleyac wesleyac is offline
AKA: Wesley Aptekar-Cassels
FRC #1678
wesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to behold
Keep G10 in mind while designing expanding mechanisms.
G10 DRIVE TEAMS may not cause significant or repeated delays to the start of a MATCH.
DRIVE TEAMS are expected to stage their ROBOTS for a MATCH safely and swiftly. As a guideline, ROBOTS should be configurable in fewer than sixty (60) seconds.
Originally Posted by The programming team
Define "works."
Unread 04-01-2015, 06:33
kmusa kmusa is offline
AKA: Karlis Musa
FRC #0639 (Code Red Robotics)
kmusa is just really nicekmusa is just really nicekmusa is just really nicekmusa is just really nice
The other thing to keep in mind is G7-C:
G7: When placed on the FIELD for a MATCH, each ROBOT must be:
C. completely outside of their AUTO ZONE and LANDFILL ZONE.
"A society without contrasting ideas will never move forward; however those contrasting ideas must be based on fact, must be rational/logical, and must be presented in a respectful manner." -Arthur Dutra IV
"If the district can spend $1.5M on turf, it should be able to fund a FRC team." -Sophie Halter
Unread 04-01-2015, 09:14
GaryVoshol's Avatar
GaryVoshol GaryVoshol is online now
Cogito ergo arbitro
Well not quite - you can't extend outside the field or onto the other side.
(since 2004)
Unread 04-01-2015, 09:52
The TRANSPORT CONFIGURATION is provided so that you can build a robot that can get through a standard door. While many venues have no obstacles between the pit and the field, many still require everything to enter and exit through 32 inch wide doors. With the door frame and hinges, 28 inches is about as wide as will fit through the opening. (Assuming there is no crash bar on the door.)
Unread 04-01-2015, 12:31
ATannahill ATannahill is offline
AKA: Alex Tannahill
You can extend over the other side, you just cannot touch anything there. I'm not sure why this would be helpful, but it is permitted.
Unread 04-01-2015, 12:38
brndn's Avatar
brndn brndn is offline
AKA: Brandon
brndn is just really nicebrndn is just really nicebrndn is just really nicebrndn is just really nicebrndn is just really nice
You can also disassemble your robot to fit it in the transport configuration. Just be sure you can reassemble it quickly enough once on the field.
