Go to Post >wears zebra pants >calls people weird - PayneTrain [more]
Unread 04-01-2015, 08:56
Charger's Avatar
Charger Charger is offline
AKA: Yiğit Korkmaz
FRC #3646 (Integra)
Charger is an unknown quantity at this point
Taking totes from ground
Which one is better? Taking totes from the bottom of them or grabbing them from the sides? Because as far as I know, totes have a little slope on the sides of them. So is it possible to take them from sides with stable parts and move them upwards by using that slope?
Unread 04-01-2015, 09:04
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Taking totes from ground
It's up to each team to decide what is better.
But remember that some totes start upside down, and others could fall that way.
(since 2004)
Unread 04-01-2015, 09:07
staplemonx's Avatar
staplemonx staplemonx is offline
The Idea Guy
AKA: JJ Biel-Goebel
FRC #1389 (The Body Electric)
staplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond repute
We are thinking of rollers on spring loaded arms. Will be doing some testing this week to find out if this makes sense.
crazy engineer
www.jjbiel-goebel.com
helping team 1389
http://team1389.com/
Unread 04-01-2015, 09:13
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
We are thinking grab from the side at the moment.
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 04-01-2015, 09:42
rjmah rjmah is offline
rjmah will become famous soon enough
Also remember that some gray totes are on the step and held captive by the lip of the step.
Robert Mah
Team 1246 Agincourt Lancers
Unread 04-01-2015, 11:21
Charger's Avatar
AKA: Yiğit Korkmaz
FRC #3646 (Integra)
But the totes in landfill zone are so close to each other, there is only little space between them. Will that space be enough to pick it from side with clap or sth like it?
Unread 04-01-2015, 12:06
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
There are several options, all of which warrant exploring.
Two narrow forks to pick up the tote from under the end lips is one approach, but you have to aim carefully to get the forks in between tightly arrayed totes.
The lip at the top of the side can have hooks go under it to grab the tote. Those four little ribs are trouble.
The top has a lip all the way around, which can be good for sliding the tote into position before grabbing it from the side via the side lip.
There may be other ways too. We intend to spend some time figuring that out as a team, after we determine the more general strategy.
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 04-01-2015, 12:21
TrevorNoon's Avatar
TrevorNoon TrevorNoon is offline
Trevor Noon
FRC #0378 (Circuit Stompers)
Team Role: Driver
TrevorNoon is an unknown quantity at this point
It was incredibly hard for us to find a way to pick them up from underneath without them flipping over. In addition to that, it seemed to need a strong support behind of it. From what I can see, most teams will be picking up from the sides.
Unread 04-01-2015, 12:36
Charger's Avatar
AKA: Yiğit Korkmaz
FRC #3646 (Integra)
but the totes in landfill zone, they are not in same position, some of them have their long side parallel to guardrails and some, perpendicular. I think it's very hard to take both of these totes from sides with stable parts attachted to telescope system or elevator, etc.
Unread 04-01-2015, 17:33
DonRotolo's Avatar
Back to humble
FRC #0832
If we think about it, we can pick up totes from the bottom, sides, front/back or top.
Which is best depends on your team's decisions on robot capabilities. What do you want the robot to be able to do?
To me, top and bottom are harder than sides. But one needs to consider the case of picking up the middle tote from a group of 3: Is there enough room to get in there to pick it up? Or, can you develop some other way to 'free' the tote so it can be picked up from the sides (or front/back)?
Thinking out loud, maybe all we need is a small 'hook' that pulls the tote out from the group to expose the sides (or front/back) enough to be picked up.
Unread 04-01-2015, 18:45
Canon reeves Canon reeves is offline
FRC #4490
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
I haven't seen anybody else talk about this, and I have yet to build a prototype. My idea was to utilize a passive system to grab the totes, and to do this, grab from the handles on the shorter sides. In short imagine putting a piece of wood up into the handle, this piece also runs along to almost the bottom for support. Basically it relies on the bottom brace to keep it upright while the lip holds the inside of the lid. Here is a link to some quick sketches I drew. https://www.facebook.com/photo.php?f... 571615&type=1
