Go to Post Your not a robot (and they aren't perfect either) - Conor Ryan [more]
Unread 03-01-2015, 21:45
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
Oculus Rift Driver Controls?
People have been discussing that even a few high stacks could impede on your view of the field. If you can't see the landfill, it would be impossible to position your robot to pickup additional totes. I imagine that on Einstein, the alliances will stack every tote building up high walls, completely blocking the driver's view. I wonder if this is the first year that using an Oculus Rift like system could be advantageous to let the driver see from the perspective of the robot. It wouldn't necessarily be an Oculus Rift, but simply watching the driver station instead of the field. Worse case scenario is knocking over your own totes because you can't see where you are going.
Unread 04-01-2015, 01:34
Edxu's Avatar
Edxu Edxu is offline
Strategy/Scouting Mentor
AKA: Edwin Xu
FRC #4476 (W.A.F.F.L.E.S Robotics)
Edxu has a brilliant futureEdxu has a brilliant futureEdxu has a brilliant futureEdxu has a brilliant futureEdxu has a brilliant futureEdxu has a brilliant futureEdxu has a brilliant futureEdxu has a brilliant futureEdxu has a brilliant futureEdxu has a brilliant futureEdxu has a brilliant future
Re: Oculus Rift Driver Controls?
IMO, the problem with having the driver use a robot-mounted camera is that robots tend to move erratically and turn very quickly, so the driver would experience vertigo (i think thats right?) and probably be less effective as a driver.
That being said, I'm all for the idea of one day having the driver have some kind of vision from the robot side.
Unread 04-01-2015, 02:04
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
There was a thread on this just a couple weeks ago. It's very hard to get good video.
Unread 04-01-2015, 02:09
AlexanderTheOK AlexanderTheOK is offline
Guy
AlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really nice
Yup. Take a look if you have time at this. It's not exactly feasible on the field, but it's a fantastic thing to do off the field.
Unread 04-01-2015, 02:42
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Personally, I think the most practical way to utilize an Oculus Rift or similar device is as an augmented reality Heads Up Display, rather than an all out video feed from the robot.
It would have the advantage of allowing important information to be in your field of view at all times without having to look at a laptop screen, and if you were cleaver you might even be able to set up a picture-in-picture with a small camera feed from the robot in the corner of your view. The advantage to doing it this way is you're not totally dependent on a real-time video feed from the robot and the robot only needs one camera instead of two.
Unread 04-01-2015, 08:01
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
There's a couple problems I can think of:
1) You'd have to stream some very high quality video from the robot. It sounds like each team will have 5+mbps to work with, but 5mbps only helps you if you're sending compressed video. Uncompressed 1920x1080 video is about 2gbps, or about 400x too much data.
The new control system is probably incapable of compressing video in real time at that bitrate.
2) Assuming you could get high-res, high-quality video transmitted, I bet there'd be lots of situations where the camera just couldn't resolve something you needed to see in the distance. Is that darker gray blob a tote, or is it another robot? You'd have a constant tradeoff between zoom levels and distant detail. You'd want a wide FOV to maneuver the bot, but a narrow one to distinguish things with detail more than a couple feet away.
Both those things said, it is probably possible to do and would be very neat, I just don't think the work required to make it happen would be worth it.
The problem is that you'd be confining the driver to a 1280x720 (DK1) or 1920x1080 (DK2)-resolution view of the world. It'd be hard to distinguish robot details looking through a OR. A HUD _would_ be good, but a better implementation might be to build a helmet with a phone mounted on top, and have a phone app that talks to your robot.
Here's a CAD model:
Unread 04-01-2015, 09:52
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Generally, when the driver's normal field of view needs to remain intact, I'd suggest a flip down/up monocular. It's a single display on a head band and you flip down that display.
At a technical level it ought to be compatible with FIRST hardware.
Outside of the technical level someone should check before they do it.
The only savings it offers you is that you don't look down to use it.
To use it most effectively you need to train your driver because it will mess with depth perception.
Unread 04-01-2015, 10:43
rjmah rjmah is offline
rjmah will become famous soon enough
Go the one step further. Put a gyro in the headband and have a mode where the robot faces the same direction as the user.
Robert Mah
Team 1246 Agincourt Lancers
Unread 14-04-2015, 22:33
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
We developed code for most of this, until it was disallowed by the rules. Check out the code release post in the programming forum.
Unread 14-04-2015, 22:57
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
As a driver, I feel that any robot with first person driving would back up into stacks all the time. One solution our team came up with is taking a really really really really tall poll with a camera on the end into the driver station that the coach holds and gives a top down view of the field. This way the driver can see the entire field at once without any obstructions.
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
