Go to Post Ironically, I think the best testament to the program [Dean Kamen] founded and his ideals wouldn't be if he won a Nobel Prize. It would be if you did. - Kevin Sevcik [more]
Unread 04-01-2015, 00:29
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
New Control System Presentation
I made this presentation on the new control system for our local kickoff today, but there was ice rain so I was unable to attend.
I still want to share it, so I will show it to you for your viewing pleasure:
goo.gl/Nb3mal
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
Unread 04-01-2015, 10:06
richwong richwong is offline
None #1701 (Robocubs)
richwong is an unknown quantity at this point
Re: New Control System Presentation
Great presentation! Thanks for sharing. Some of the links were very helpful for us.
Unread 04-01-2015, 10:40
pipsqueaker pipsqueaker is offline
FRC #1124
pipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to all
Hey, I have a question for you- do the CAN buses on this year's components have any directionality? The reason I'm asking is that none of the CAN buses have input or output sides specifically labelled- also I've seen that on another team's presentation, they terminated the CAN system in the PDP in adifferent set of ports than on the official wiring diagram.
The information i have leads me to believe that the CAN bus's directionality regarding I/o will not change anything, but I still wanted to make sure.
One last question- if you're not terminating the CAN in the PDP, terminating the signal is a matter of wiring a 180ohm+ resistor into the final socket, correct?
Unread 04-01-2015, 11:08
As described in the wiring document, there is no specific in or out on the PDP or PCM.
It should be 120ohm exactly not 180+
Unread 12-01-2015, 14:47
millerxela1629 millerxela1629 is offline
FRC #1629
millerxela1629 is an unknown quantity at this point
Nice
