Go to Post Coming to MTV this fall: Pimp my Segway - Francis-134 [more]
Go Back   Chief Delphi > Technical > CAD
Unread 04-01-2015, 10:30
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
PTC download for mentors
On the PTC download page, you have to select that you are a HS student, a college student, or a K-12 educator. I am none of these, I am a mentor. I use Pro/E at work, but it is not compatible with the student version, and I would like to have that version installed at home so I can look at and help with student CADding.
Should I just click K-12 educator since that is what I am doing? Would that be dishonest?
Former Mentor Team 1771
Former mentor Team 4509
Unread 04-01-2015, 11:27
adammiller3122's Avatar
adammiller3122 adammiller3122 is offline
FRC and FTC Mentor
AKA: Adam Miller
FRC #3122 (The Alluminators)
adammiller3122 will become famous soon enough
Re: PTC download for mentors
That is probably what I would select or student. They will all give you the same edition.
Adam Miller
New Ulm Robotics - Alumni
FRC Team 3122: The Alluminators (mentor)
FTC Team 8005: Robot Renegades (mentor)
FTC Team 10493: RoboWarriors (mentor)
homepage: newulmrobotics.com
Unread 04-01-2015, 12:53
martin417's Avatar
AKA: Martin Wilson
Where do I get the license for CREO?
Unread 04-01-2015, 21:48
Generator of Entropy
FRC #2973 (The Mad Rockers)
Paraphrasing here, having just done this recently:
If you select K-12 Educator, it will take you to another section with pull down menus; one of the choices is coach / mentor, and another pull down menu that asks how you will use it has FIRST Robotics as a choice. You will get download instructions that are pretty straightforward.
Once you register for an ID on PTC.com, when you go through the software download process at some point it will ask you to login to your PTC account. At that point during installation it will ask you for a product code, which you will get in a link to more instructions. I gather that it is looking at your PTC account to make sure the code matches a license that has been issued to you. It will then begin the installation of the software that was downloaded.
PM me if you have any issues, I printed out all the instructions but I have to find them. I had to do this 3 times (my personal copy and the 2 copies we have at our build facility).
Unread 05-01-2015, 10:50
_Daniel_Gonzo_'s Avatar
_Daniel_Gonzo_ _Daniel_Gonzo_ is offline
Gonzo
AKA: Daniel Guillermo Gonzalez
FRC #2582 (Pantherbots)
Team Role: Electrical
_Daniel_Gonzo_ will become famous soon enough_Daniel_Gonzo_ will become famous soon enough
Whenever you choose to start the download, PTC should take you to a pdf page with links and instructions. DONT EXIT THIS PAGE, KEEP IT OPEN UNTIL INSTALLATION IS OVER!!! Because if you lose it life goes south real fast... Anyways, the install PDF will have a key for you to use in the setup process, its conveniently laid out!
Good Luck
