#16
Re: Humans Stacking Crates
Mineboy2300: If I understand your strategy to mean that yellow totes are stacked and placed by human players on the field below the chute, then I believe G13 and by extension Section 3.1.4: Match Logistics prohibits this approach. You have two options, leave your totes on the field in the staging zone or remove the yellow tote from the field and place it in the designated starting position of the alliance station.
"However, if a DRIVE TEAM elects to leave their Yellow TOTE in the STAGING ZONE, they must leave it as positioned by the FIELD STAFF." Also, from the blue block below Figure 3-7. "There are no rules that prohibit a ROBOT from being in contact with TOTES or RECYCLING CONTAINERS at the start of the MATCH, as long as those items were not moved from their STAGING ZONE..." |
#17
Thanks BenBraun3090! My bad, carry on!
#19
Our students found that if you opened the door quickly the tote landed flat on the ground. Any hesitation at all resulted in a tipped over tote.
#22
Does anyone have video of their team testing their different techniques on the Kickoff fields?
#23
This is an interesting point. I can't say I remember if I was hesitating or not. We'll do some more testing once we have a human player station built.
#24
Can someone that has built a loader station (or saw a real one at kickoff) comment on how fast a reasonable human player can load totes onto the field/robot? I assume they have a nice stack right next to the loader. Please let us know if there is a reason to go fast or slow to get it to fall best on the ground.
Thanks! -matto- |
#25
Evan |
#26
The totes can be stacked if aided by a robot. During our tests we found that the totes most likely will no land bottom down, but if we place a solid object (such as a robot) a few feet in front of the chute we found that It can reliably stack two totes to be transported.
#27
I believe this rule is stating that a human player is not able to open the chute, while still holding onto the tote, therefore being able to place the tote however he/she wants onto the field.
#28
I'd like to know how quickly a human player can safely put 6 totes through the chute (assuming the robot is capable of moving the totes out of the way fast enough to keep the chute exit clear - say a conveyer belt). Has anyone built the human player station and able to time this? An approximate time is good enough - are we talking 10 seconds, 15?
Thanks Steve |
#29
so G6 A single ALLIANCE member may not be in contact with both a TOTE and the CHUTE DOOR simultaneously..
please not the word SINGLE. There are 3 HP's and only 2 alliance stations. Can one HP open the door while the second HP pushes the bin through? Or for that matter can one HP hold the door open while the second does a continuous feed or some version of that? |
#30
G5 Only one ALLIANCE member may be in each HUMAN PLAYER ZONE at a time. VIOLATION: FOUL. Additional FOUL for each TOTE entered onto the FIELD while in violation of this rule. |
