Go to Post It's hilarious to watch this conversation about a box which probably has a 95% chance of being robot batteries turn into all kinds of bowling ball conspiracies. - artdutra04 [more]
Unread 04-01-2015, 16:33
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
mecanum wheel postioning
Yesterday while talking with one of my mentors about the use of mecanum wheels on our bot this year, he mentioned concern about whether the wheels must be configured in a square. I told him that I was pretty sure that we could have them in a wide configuration as well (to aid in turning) however I wanted to double check here.
Can I place mecanum wheels like this without doing mass amounts of math and programming to compensate:
Or Must they be square like this:
Unread 04-01-2015, 16:37
Re: mecanum wheel postioning
There should be no change with regards to the programming for a long, wide, or square robot. Ether, you want to chime in here?
Unread 04-01-2015, 16:44
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
From my experience, the only difference it will make is the side with the longer aspect ratio will be more difficult to move directly in that direction. For example:
would be more diffcult to drive straight vs. strafe left and right, while
would have much more difficulty strafing, and would be able to easily drive forwards and back.
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 04-01-2015, 16:48
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Also, keep in mind that this becomes fairly easy to compensate for with a gyro and field-oriented driving.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 04-01-2015, 17:06
AKA: Brian Wagg
FRC #2386 (Trojans)
That is what I had thought. One other question is do both left wheels have to be collinear with each other, or can they be spaced apart so long as they are parallel.
or must they be like this:
Unread 04-01-2015, 17:18
Theoretically, if the wheel pattern is not square then trackwidth and wheelbase lengths should enter into the inverse kinematic computation if you want the rotate command to correspond with actual engineering units:
FrontRight = FWD - STR - K*omega
FrontLeft  = FWD + STR + K*omega
RearLeft   = FWD - STR + K*omega
RearRight  = FWD + STR - K*omega
... where:
FrontRight,FrontLeft,RearLeft,RearRight are wheel tangential speeds, ft/sec
omega is CW rotation around center of area, rad/sec
FWD and STR are driver commands, ft/sec
K is (trackwidth + wheelbase)/2, ft
WPILib and LabVIEW don't support this, so you would have to scale your rotation before calling these methods.
If you don't scale the rotation, it won't cause wheel scrub. It just won't correspond to the rotation you expected.
Unread 04-01-2015, 17:23
The inverse kinematic computations in WPILib and LabVIEW expect the wheels to be colinear on both sides. A small non-colinearity would likely still work, but wouldn't be ideal.
Unread 04-01-2015, 19:20
...if the wheel pattern is not square then trackwidth and wheelbase lengths should enter into the inverse kinematic computation if you want the rotate command to correspond with actual engineering units...
Here's a simple example. Suppose your bot has trackwidth 22 inches and wheelbase 26 inches and you want to create a special code to drive around in a 6 ft radius circle at 4 ft/sec speed (see sketch).
FWD = 4
STR  = 0
omega = 4/6
K = ( (22/12) + (26/12) ) / 2 = 2
FrontRight = FWD - STR - K*omega = 4 - 0 - 2*(4/6) = 2.67 ft/sec
FrontLeft  = FWD + STR + K*omega = 4 + 0 + 2*(4/6) = 5.33 ft/sec
RearLeft   = FWD - STR + K*omega = 4 - 0 + 2*(4/6) = 5.33 ft/sec
RearRight  = FWD + STR - K*omega = 4 + 0 - 2*(4/6) = 2.67 ft/sec
If you didn't take the wheelbase and trackwidth into consideration, the rotation would not match the forward speed and you wouldn't get the expected vehicle motion.
Of course, if the driver interface is simply going to be forward, strafe, and rotate commands, then it doesn't matter. The driver just adjusts the commands (after much practice!) to make the vehicle do what he wants.
Unread 04-01-2015, 20:23
Here's another example.
Suppose you want to pivot the bot clockwise around the front right wheel (see sketch) at 90 degrees per second.
Trackwidth = W = 22/12 ft. Wheelbase = L = 26/12 ft.
ω = π/2 rad/sec
FWD = ω∙(W/2) ft/sec
STR = -ω∙(L/2) ft/sec
K = (L+W)/2
Unread 12-01-2015, 12:03
goofy173's Avatar
goofy173 goofy173 is offline
Electronics Mentor
FRC #2867 (ElkLogics)
goofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to all
Because of stability, I would space them as far from each other as possible. We have ours outboard of the KOP chassis but we'll be raising them up a little from the stock holes as the chassis is dragging just slightly on the scoring ramps.
Unread 12-01-2015, 13:59
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
In case you find a source code example helpful:
Here's a link to some java drive subsystem code that's based on Ether's Inverse Kinematics equations, there are some coefficients in there for the wheel base (length and width) as well as for wheel diameter that account for the issues being discussed.
This code also has optional field-oriented drive in it as well, and support for speed control via quadrature encoders ("traction control"). Team 2465 has found both of these to be helpful, and think they're useful for this year's game. This code is written to work w/black Jaguar motor controllers.
There are other examples posted on ChiefDelphi that you'll find, too.
Unread 12-01-2015, 17:24
idahorobot's Avatar
idahorobot idahorobot is offline
FRC #2130 (Alpha +)
idahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the rough
The link did not work.
Unread 12-01-2015, 17:40
markmcgary's Avatar
markmcgary markmcgary is offline
Software Mentor
FRC #4322 (Clockwork Oranges)
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
How about this one?
Unread 12-01-2015, 17:54
Software Mentor
AKA: Scott Libert
Here's a direct link to the Drive.java file.
The previous link works for me, but it leads to a source code browse view, so you need to navigate around a bit to get to the Drive.java file above.
